Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 intake modification
Old Jul 28, 2008 | 05:14 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
anyone know where I can send a LT1 intake to get the distributor hole only drilled? and I will be needing a angled spacer, but I figure I should be able to get that from the same place
if no ideas, here is a question, are the rear intake bolt holes in the same location on a standard SBC intake as on the LT1 intake? i am asking so if needed, I can check local machine shops and see if one can do it, after locating the hole off one of the SBC intakes I have
Old Jul 29, 2008 | 01:25 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 intake modification
https://www.thirdgen.org/forums/engi...ntake-4-a.html
Theres alot more to it than just cutting a new hole for the distributor
Buy a kit from this guy and have no worries or do the research you obviously havent and DIY for about the same if not a little more cost
Old Jul 29, 2008 | 06:00 PM
Dave Y's Avatar
Engine: 4.3L V6
actually, yes, all i need is the hole and spacer, as this will be on an LT1 engine
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
