Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
help with wiring
Old Aug 5, 2008 | 06:09 PM
383HSR's Avatar
help with wiring
ook so the thing is i had a 350 tpi in my TA i'ts now dead loll...i'm now biulding a 383 with the HSR i got the complete kit from holley with the commander 950 ecm management and i'd like to know if someone here can help mewith the wiring of this....i have a brand new wirin harness thath came with the kit but the thing is that when i took off the old wiring harness of the stock TPI there was wire going inside of the driver area so i dont know if i can just ignore those wire or what??
Old Aug 5, 2008 | 07:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: help with wiring
What year TA
Do you have a wiring diagram for the Holley harness?
What wires are left to connect to the main harness?
Pics help
Old Aug 5, 2008 | 08:02 PM
vwdave's Avatar
Its been a short while since I've done the wiring on my car, so yeah.
On my 89 RS, the big bulkhead connector on the side does a bunch of things. But if you have a book, take your time you should be ok.
Mine had the headlight/turnsignal harness, all the misc crap for the gauges such as oil pressure, coolant temp, possibly the tach wire, wiring for FP relay, AC compressor might be in there too. Not too sure. A few other misc stuff too.
Old Aug 6, 2008 | 08:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The Holley setup only needs 12V power to run as a stand alone system. It has all the needed connections.
You need a factory wiring diagram to see what wires you want to
( not need to ) keep that run from the engine bay to inside such as A/c ,lighting etc.
Old Aug 7, 2008 | 08:32 AM
383HSR's Avatar
ook that's what i was thnking of doing but the thing is the wires that i want to keep were do i route them if they were goign to the stock computer???will i have to run 2 computer in the car
Old Aug 7, 2008 | 09:22 PM
Pocket's Avatar
Car: 91 Trans Am
What aspects of the car will the new ECM not be running that the old ECM does run?
Old Aug 9, 2008 | 05:21 AM
383HSR's Avatar
i'm not sure but the only thing i can see that those wire are is the ac the light and for sure i know that there is the vats system that works with the key...the new ecm will control only the engine sensors that's it....i'd have to check the haynes to know exactly what's really going through these wires there I'll get back to you when i'll find the answers
Old Aug 15, 2008 | 03:09 PM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
I am very interested in this myself. I want to use this set up to put on a 408 stroker race motor. not the HSR but the 950 Commander 4v TBI System. That system can handle up to 600 hp. It uses the same ECM system as the HSR. But I need to know what to plug into and where for the rest of the car's system. Also, did you use the stock distributor and Alternator from your old TPI?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
