Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
mini ram help
Old Aug 28, 2008 | 07:25 PM
Gutz's Avatar
Car: 89 GTA
mini ram help
Hi i bought a used mini ram and went to install it today and i'm having trouble getting the middle bolts in.Obviously i can't use my factory tor-x bolts so i went and got some boxed head bolts.But i still can't get them in.On the drivers side it looks like its grinded out a little from tpis but not enough and then nothing on the passenger side.Do i need special bolts or grind it out or am i just stupid. Thanks for your help.
Old Aug 29, 2008 | 12:07 AM
Gutz's Avatar
Car: 89 GTA
Re: mini ram help
I have just been looking at some pics of other peoples's mini ram's and mine is different.I'm wondering if maybe i got an older intake or something.It doesn't have the opening in the middle of the intake like the other ones i seen.
Old Aug 29, 2008 | 05:37 AM
AC's Avatar
AC
Car: Used to drive a camaro
Re: mini ram help
Call TPIS. You may have an older casting that is not made for your type of heads. Are your heads center bolt or parameter valve cover bolts?
Old Aug 29, 2008 | 10:21 AM
Gutz's Avatar
Car: 89 GTA
Re: mini ram help
There centre bolt heads.I'll give them a call.
Old Aug 31, 2008 | 10:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: mini ram help
I believe the later ones are "air gap" as in a space between base and plenum.
What about socket head (allen head) cap screws ?
Old Sep 1, 2008 | 09:54 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Re: mini ram help
Get some ARP intake manifold bolt set. I think I know what you are talking about, the Miniram has small "pockets" for the mainifold bolts. Im running a set of ARP bolts on mine and have ZERO issues with it. They have a 7/16" hex head on them kinda like header bolts.
Linson
Oct 24, 2025 02:00 PM
cowansauto
Apr 3, 2025 12:51 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
09ave
Sep 7, 2015 06:03 PM
