Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
k&n throttle body mount filter vs standard filter
Old Feb 2, 2009 | 02:03 PM
criesofthepast's Avatar
Car: 87 Iroc-Z
Engine: 305 5.0
same thing? which ones better? how much hp increase if any?
Old Feb 3, 2009 | 11:20 AM
Ronny's Avatar
Re: k&n throttle body mount filter vs standard filter
oops.
Old Feb 3, 2009 | 11:37 AM
David 91RS/Z28's Avatar
I had ran a TB mounted K&N on my car when I first started modifying it. Later on I made my own custom air intake with 3.5" tubing, impala ss elbow and the same K&N. It's been a while but I remember picking up a tenth or so at the track. This was all done when I was running a 305. All the TB mounted filter will do is suck the hot air from below. Remember this will only work on the 90-92 Speed Density systems.
Here is a link to what I built: http://www.i-55.com/~davidlt/air_intake.htm
Old Feb 3, 2009 | 12:16 PM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
I used the TB mounted K&N for a while. Last summer I switched back to the stock air filter setup and didn't notice a change other than the sound. I think it might even hurt performance because of the air temp. Your best bet would probably be a couple of stock replacement K&N filters and reduce the restriction under them. But even that would not make much of a performance difference on a stock 305.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
