Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Miniram owners - step inside
Old Feb 18, 2009 | 01:20 PM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
I'read somewhere that installing Miniram or converted LT1 intake
on L-98 that uses stock ECM can cause problems.
It looks like problems are with air distribution inside the plenum,
and this causes front cylinders running rich.
Does anybody here that uses miniram now something more
abut this?
I'm considering switching to miniram (from superram) and I wouldn't
like to get into those kind of problems.
Old Feb 18, 2009 | 02:20 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: Miniram owners - step inside
I experience this with my Miniram. The problem is on the back cylinders 5,7,6,8. I believe this mostly at idle and very light throttle. WOT should not be a problem. Right now I'm working on a fix for mine.
Old Feb 18, 2009 | 02:35 PM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
How do you plan to fix this?
Old Feb 19, 2009 | 06:46 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
I'm planning on plumbing my crankcase ventilation into the exhaust. Moroso, Jegs sells the kit. I will then run a hose from the throttle body to the vacuum port on the plenum. This will feed fresh air into the plenum at idle and should have zero efect on WOT.
The car is in storage right now so will not have feedback until May or June.
Old Feb 19, 2009 | 09:23 AM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
O.K. Thanks for the input.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Chad Speier
Sep 24, 2015 12:32 PM
Fronzizzle
Sep 8, 2015 12:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
