Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
switching from tpi.
Old May 18, 2009 | 09:00 AM
mikeselky85's Avatar
switching from tpi.
I was thinking since the TPI system will leave me stranded with no power, so i was wondering how hard it would be to swith to an efi manifold and run an ls1 throttle body with the elbow? I was wondering if I could keep my tpi harnes ( speed density with emisions delete). I was wondering what parts i should be looking into. I would like to later on add a turbo to my car, but only when money is around.
Old May 18, 2009 | 09:11 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: switching from tpi.
What are you saying u want to change TPI to carb????
Old May 18, 2009 | 01:19 PM
90c350's Avatar
Pretty much any single plane efi manifold will work for you! holley/Edeldbrock/Profesonial products/Weiand etc all make good single planes with injector bungs etc. Then Edelbrock has some nice elbows that will accept the Ls1 throttle body and your good to go. Do some searching in this forum under single plane intakes and you will get alot of answers. Hope this helps
KarlJ
Oct 9, 2015 03:43 PM
tglennon11
Sep 23, 2015 05:30 PM
pacoelrapido
Sep 11, 2015 02:41 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
