Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 superram vs tpi superram whats the diff? or is it a typo?
Old Jul 7, 2009 | 12:13 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i have found a superram forsale but the guy says its for a lt1.....is he thinkin its for a l-98-tpi or is there really a superram for a lt1 motor? the pics looks like a normal SR. The price is good and i want to jump on this but i have a l-98 motor not an lt1 so i want to make sure on this.
Old Jul 8, 2009 | 12:39 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: LT1 superram vs tpi superram whats the diff? or is it a typo?
See if he has a pic of the intake manifold.
LT1s are different.
LT1 intake is supposedly better than the SR, but you have to block off lots of things, and do an adapter for the distributor.
Someone who knows this stuff cold should answer soon.
In the meantime, I'd look at some pics, and move ahead.
Good luck.
Old Jul 9, 2009 | 02:49 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I've never heard of a Superram intake for an LT1, not saying they don't exist. But there are guys running 9's on a factory intake, it flows plenty. Certainly quite a bit more than a stock TPI intake will.
Old Jul 11, 2009 | 12:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
# 374719L LT1 base for Super Ram
Note the spacing on the 2 center intake holes.
http://yitbos1.smugmug.com/gallery/8...63299895_SC6WU
Appears to be regular SR base drilled with LT1 intake bolt pattern ; still has the dist hole , thermo housing and front coolant passages.
Used with the regular SR plenum and runners although they made a lower height plenum (#74196F ) to fit LT1's in 4th Gen cars.
https://www.thirdgen.org/forums/tpi/...1-intakes.html
Buy it and get the center holes redrilled to suit L98?
Originally Posted by Flip 2
LT1s are different.
You are confusing a stock LT1 intake with a stock L98 one. Intake in question is SR base modified to work on LT1 heads.
Old Jul 11, 2009 | 01:49 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
YES! They did make the SR base that fit the LT-1. The SR that I bought for one of my cars was from a LT car. i sold the lower (LT-1) intake and bought one for a L98. These were made by Lingenfelter and there were very few of them made. They used undrilled castings from Accell and drilled the intake for LT-1 and not L98. the dist hole was plugged along with the t-stat hole.
Here is some pics of the one I had. you can see the holes were never drilled for the L98 and where the holes are drilled for the LT
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
draco
Oct 4, 2015 09:25 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
