Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
will this ebay afpr work with HSR???
Old Nov 17, 2009 | 07:46 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
alright iv heard that you can use a buick grand national fuel pressure regualator on a holley stealth ram. so instead of just going out and buying a holley brand afpr, i searched to see how cheap a guick gnx afpr was. well on ebay i found these after market ones, but not quiet sure if they look legit.. or if itd work on a hsr fuel rail.. the fittings look like theyr for rubber lines.
so heres a couple links of them on ebay. this first one im not sure if its for like a tbi or a carb using an electric fuel pump. because the gauge only reads up to 10psi.. i think, the red line around the gauge could be it too which is like 140psi(which would make sense)
http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
another one
http://cgi.ebay.com/ebaymotors/BA-FU...Q5fCarQ5fParts
and another
http://cgi.ebay.com/ebaymotors/FUEL-...ltDomainQ5f100
Old Nov 22, 2009 | 12:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: will this ebay afpr work with HSR???
Not bolt on fit;
would work if you plugged the hole in rail and ran rubber hose to reg listed
Have to read the fine print in advert
"THIS LISTING IS FOR A UNIVERSAL FIT FUEL PRESSURE REGULATOR, NOT A BOLT ON FUEL PRESSURE REGULATOR MADE TO FIT CARS LISTED IN THE AUCTION TITLE ****
The HSR /GN /LT1 regulator has a machined spigot with a O ring that seals into the rail like this $$$ one and is held in with a bracket.
http://www.summitracing.com/parts/AE...6/?image=large
Old Nov 23, 2009 | 06:56 PM
1hotroc's Avatar
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
So does that fuel pressure regulator take the place of the one provided with the stealth ram fuel rail kit. Is it a direct bolt in. Much appreciated on an answer.
Old Nov 23, 2009 | 07:07 PM
Engine: 383 hsr
thats excaclty what id like to know too, look how CHEAP it is LOL. but according to vettoez, its not a direct bolt on. its has the provisions for rubber/plastic fuel lines. but i still wanna know if that can be incorporated to work...
Old Nov 23, 2009 | 07:45 PM
1hotroc's Avatar
Car: 87 iroc
Dude do yourself a favor and check out this adjustable FPR its made by Kirban pn# 6547. Its a direct bolt in. Kirban is a company that caters to the grand national but it will work with the HSR. Check out there website it's only 105.00! Im getting one tomorrow. Hope this helps.
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Aug 25, 2015 09:14 AM
chazman
Aug 11, 2015 11:19 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
