Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR plenum gasket replacement
Old Feb 8, 2010 | 06:51 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
anyone know where i can buy replacement intake to plenumm gaskets for the hsr intake, having a hard time locating them, i have a slight vaccum leak there so i need to replace asap, pic attached of gaskets needed.
Old Feb 8, 2010 | 06:57 PM
Twin_Turbo's Avatar
Re: HSR plenum gasket replacement
Same as Weiand Tunnel (Hi) Ram gaskets, available with or without dividers. Holley 108-119 or Weiand 8984. Summit, Jegs.... you name it.
Old Feb 9, 2010 | 10:20 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
If your in a bind, you can also make your own with a sheet of gasket material.
Old Feb 9, 2010 | 04:34 PM
godreject's Avatar
thanks twin turbo.
Old Feb 9, 2010 | 04:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
abit more mess but rtv works great
Old Feb 10, 2010 | 04:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
rtv works great
Works for me
Old Mar 29, 2010 | 08:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
Ya just spread it out and let it set up a bit before you go and bolt the plenum down
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
qz6lwp
Aug 20, 2015 08:10 PM
MY87LT
Aug 17, 2015 08:43 AM
