Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
will sr runners work with a first tpi intake base?
Old Aug 15, 2010 | 03:21 PM
c4mo's Avatar
I realize the base will have a lot bigger ports but is the bolt pattern the same? Also wondering if i could use a gm fuel rail also? thanks for any help
Old Aug 15, 2010 | 03:48 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: will sr runners work with a first tpi intake base?
Guess it is completely different...
Old Aug 16, 2010 | 10:46 AM
BadSS's Avatar
The bolt patters for the runners are different as well as the fuel rails. Neither the SR runners or the stock TPI fuel rails are "bolt on" items and both would require a good bit of modification to work on the FIRST.
Old Aug 16, 2010 | 03:54 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Yep, the First TPI system is a completely different setup. Its still a LTR design but nothing is compatible, not even the throttle body.
Old Aug 17, 2010 | 08:33 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
There has been some hogged out SLP runners that were made to fit the first base to flow over 300CFM but it was a load of work....there is a nice thread about it some place!!
We need some one to make a SR setup to fit a first base!!
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
tazs2000
Jul 15, 2017 08:44 AM
st.evel07
Aug 13, 2015 06:15 PM
