Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Want to go HSR, starting from a carb'd 406?
Old Oct 3, 2010 | 09:25 AM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
Hello All,
I am looking to buy a new project car, and one of the cars I have in mind currently has a carb'd 406 in it. The car was no originally carb'd, so I am assuming that the wiring harness was stripped down (all of the gauges still work though). How much of a hassle would it be to take it back to EF using a HSR?
Thanks!
Old Oct 4, 2010 | 11:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Want to go HSR, starting from a carb'd 406?
Just need a TPI based computer and wiring harness, and all the sensors that motor would normally use.
Mount the ECM in the car and then just hook up the harness.
If your factory gauges still work thats a good thing. Less work you have to do.
being an 88 it would be a MAF based car. I dont know if you have any of the wiring left or not, but i'd get a new 165 ecm from a 86-89 TPI car and the MAF sensor. Use what you can from your original wiring if there, or just get a new complete harness from one of the MAF tpi cars. Then just need a 89 6E based memcal/chip and start tuning for the 406.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
