intake gaskets #'s
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
intake gaskets #'s
so I've been running very lean at idle. I finally traced it to a vacuum leak between the Edelbrock Hi-Flo Base and my Brodix 200IK heads. I pulled the lower intake today and noticed that the intake gasket GM# 10159409 that Edlebrock calls for the intake is to small and doesn't cover the top 1/16" of the runner in my heads. My engine builder originally had Fel Pro #1205 installed on my setup. So what intake gaskets do you guys suggest for a 200cc head to Edelbrock Hi-flo lower intake. 1205,1206? Thanks
Car: 89 Formula 350
Re: intake gaskets #'s
leaning toward the Fel Pro 1205s, just want to confirm before ordering them.
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I would agree with ur choice. To be safe check with the tech dept from both manufacturers and see if there is a similarity in their recommendations. Good luck!
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
