Best injector for Hsr setup
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Hey guy I just bought a Holley stealth ram with all the upgrades and stuff putting it on my soon to be a 383 stroker. I'm putting a new upgraded fuel pump I believe it's the walbaro 255 and I'm wondering what size injectors I would need or the best to match..
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
Re: Best injector for Hsr setup
we need to know what heads are on the 383 and what the 383 is bored out to.
probably around 30-40lbs injectors.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Sorry it's my 350 l98 that I'm going to be stroking out to a 383 and my heads will be stock aluminum heads from the l98 just ported out with Lloyd elliots LE2 package with a 230/236 112 cam. I saw some accel 32lb injectors or some Trick Flow 30lb injectors.. I don't
Know which ones to go with..
Car: 88 Formula
Engine: 388
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
30lb injectors will be fine for what you are planning... thats what im running with no problems at all
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep good choice, 32lbs will be plenty for that. Should be a stout 383..watch your compression with those L98 LE2 heads....
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
With my setup up whAt do you think
Will b the best compression for the l98?? Help I'm new and want the best thanks
As to the injectors, still need more info....heads, cam, compression...start there.
the answer is somewhere between 24 and 36 pounds....
So help us narrow it down.
Car: 89 Iroc-z
Transmission: TH400
With that cam, 10.5 would be great on pump gas which will require a deep dish piston since L98 heads are 58cc as cast and LE will shave them abit to make sure the deck is straight so they may be as low as 54-56cc. Thats gonna create very high compression with a flat top piston so you will need a big dish.
Now, a 383 with that size cam and those heads, I'd look at 36lbs. I like injectors a little bigger, it's safer than going borderline small. I'd expect about 450 CHP with a Stealth Ram setup, give or take. So yeah 36 Bosch.
As to the compression like Orr says, 10.5 is a nice range. I think this is a great combination and you're going to enjoy it. Should fall off over 6000 RPMs.
Give me a call on them. 201-258-5600 We can work it out.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Neither. Honestly. Neither. Neither Accel or TFS make their own injectors. They are Lucas, Bosch, or Delphi I'm not 100% sure which as they all change from time to time. Do not pay more for a name.
Though, a 36# injector would probably work fine for a 450hp motor too. I'm happy with idle pulse widths in the 2ms range. You can always make an injector look a little bigger by raising the fuel pressure, but when you try and go the other way you risk issues. Injectors to me are like cams, start small because too big will bite you.
-- Joe
Some guys have good luck with big injectors, other guys have problems. I guess it all depends on the injector. I'd run a 36# injector to 550hp on a naturally aspirated motor, because I'd rather run a 50psi rail pressure with a nice spray pattern, and a reasonable idle pw than dance on the 'erratic' idle side of things just to keep the DC down. I've never had a problem with bosch II, or bosch III's going static like the older rochester injectors. But I have had issues at idle with motors that had tame cams and low compression but ran MASSIVE amounts of boost and needed the fuel at WOT.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running 42s on a similarly powered engine, slightly higher. I'll admit they're a little large, but they work. I do agree with raising the fuel pressure as a fine tune. Different ways to skin a cat. But understand, when people say to me "what injector should I use" I err on the larger side. I don't want to make a suggestion that's going to melt a piston...as I have seen happen more than I care to.
Just for numbers sake, at a BSFC of .55, which, for a N/A motor means you totally missed the combo but lets err for caution, at 50psi rail pressure which is quite reasonable, 36# injectors will support 500hp at 90% duty cycle.
Now one thing to take into consideration is is RPM right - a 230/236 cam on a 383 is going to be done by 5800, so in theory you have about a 10ms firing window before going static on a typical batch fire ECM.
-- Joe
Yeah, I like to keep the DC in the 80s. Everyone has their preference and none is right or wrong. I like having more than 10% overhead, for no good reason other than it makes me fee better.
-- Joe
-- Joe
I think he can get better than 5800 RPM thinking 6000...have to put it together to see. He does have the LE heads....
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The motor will probably valve float around 6500rpm or higher, and most guys do shift past peak HP. But past peak HP the fuel requirements diminish, so while your DC quickly approaches a higher percentage, your AFR actually richens up a little bit.
Different stuff works for different combos.
I've changed my ways quite a bit over the past 10 years. I used to promote big injectors and precise closed loop tuning but over time I've found that what works on a RACE CAR is not even close to what works on a daily driver. Now, I run open loop only, smaller injectors with high rail pressure, crap tons of initial spark advance (24-26* at idle, and add 10* by 2800 RPM for wot), no PE spark. Many sessions of tuning cranky minirams and friends stealthrams with big fat cams have made me throw many 02 sensors in the garbage and instead tune for 'best performance, most idle vac', etc.
-- Joe
[/quote]The motor will probably valve float around 6500rpm or higher, and most guys do shift past peak HP. But past peak HP the fuel requirements diminish, so while your DC quickly approaches a higher percentage, your AFR actually richens up a little bit.
-- Joe[/QUOTE]
Any miniram advice? I'm in MR hell.
My ECU (motorvation) allows setting parameters for closed loop. You can set RPM, TEMP, just about any parameter. If it's not THIS stay open loop. Do idle is at open loop, once it hits 1200 RPM I throw it into closed.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On an auto (700R4) with 3.54 gears, a cc-306 cam, miniram, and a small block I it was ok with a loose (3k stall) converter. Manual transmissions amplify problems with the tune, where loose automatics kind of dull the issues.
Now as far as idle, I could never quite get the MR to idle properly. I had patched bins that would disable closed loop at idle, and resume closed loop at
> 1100rpm, but even then the transition was hard to fix.
The miniram has the same problem at lot of those intakes do. You have 8 cylinders running differently, and one narrowband 02 sensor trying to figure out if it's rich lean or in between.
My advice is to not use closed loop at all. Lean out idle, ramp in tons of advance to get good vac. Work out your AE transitions, and build a nice cruise map with high 40s SA, and a nice lean burn. Then tune PE fuel for best power.
Another thing to be careful about, is make sure your staying in your powerband. You load the thing up too much under your powerband and you'll have all sorts of issues. I know my C4 had 2.59 gears stock which were laughable with anything that even comes close to a 'performance' camshaft. A 3.54 gear ratio is about on par with a 700R4 and a mild performance cam (230*)
-- Joe
Car: 89 Iroc-z
Transmission: TH400
I also run abit larger injector now. I had 42's on my 400whp 383 which probably could have done 36's. No idea what the PW were so no idea what the DC's were. My 401TT motor I have 80's running 48psi. I think i'm near 84% DC if calculated right but its abit richer than i need it so still have abit of room to play with. It actually idles fairly well for being a larger injector (newer siemens).
now your idle defination of "nice" may vary, but I am happy with it. Stable in drive and doesnt stall but its abit higher rpm than I want. Still need to tweak.
My 383 was a MAF car so didnt have to pick to hard at VE tables like the 401TT motor. MAF compensates well. Some other motors I've helped tune were all MAF's too. Various 350-383 setups. Idle well with a big cam too. Some closed loop, some open. Both did ok on MAF but my setup was all open loop.
Depending on the lobe shape/lift that 230/236 cam may go abit beyond 6000 rpm peak. My 230/245 went to 6250 peak and held to 6500+
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
