Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
400whp
Old Dec 1, 2010 | 06:54 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
400whp
The question I have is has anyone on TGO made over 400whp with a 355 TPI without S/C or NOS and with shorty headers?
Old Dec 1, 2010 | 09:29 PM
DON 88T/A's Avatar
Re: 400whp
I've never seen anyone make that claim and I've been here since 1999...
Superram could do it with enough compression....
Old Dec 1, 2010 | 09:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 400whp
agree..don't recall seeing one. LT1's yes..quite common to see over 400whp with heads/cam/ported intake and I think I recall seeing one near 500whp with solid roller in a race setup. No reason a TPI based motor you guys build cant do the 400whp...but keeping it smog legal "legally" (read no special techs giving a sticker) is another story.
Old Dec 2, 2010 | 07:25 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: 400whp
When you or we say "TPI," just how true to a General Motors Tuned Port Injection induction are we talking? Almost immediately in the thread, the Super Ram, Mini Ram, Stealth Ram, First intake, or a (mildly to wildly) modded LTR (TPiS, SLP, ACCEL...) set-up enters the equation. If the HSR qualifies, and I don't think it should, I missed 400 by three little stallions on one day, on one pull, on the same dyno that recent SoCal dyno testing / tuning has been done on. Please define "TPI." Thanx!
Bill
Old Dec 2, 2010 | 10:20 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: 400whp
hmm... if only they knew
Old Dec 2, 2010 | 10:34 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 400whp
Bill
If it were me, I would say anything that has tuned runners.
If you are specific, then GM type stock, or with aftermarket runners.
I think my setup will make the 400, as it did 389 with an auto and now it's in my stick car.
Old Dec 2, 2010 | 11:13 AM
Burnout91's Avatar
Engine: Modded L98
Re: 400whp
Thank you!
Old Dec 2, 2010 | 09:51 PM
VincentZ28's Avatar
Re: 400whp
Ok any aftermarket intake with the stock factory wire harness(7730 or 165 ECM)
Old Dec 2, 2010 | 10:24 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 400whp
A thread like this is better suited in the TPI forum. This forum is for is for alternative intakes.
-- Joe
Old Jan 31, 2011 | 10:13 PM
CamaroIROC88350's Avatar
Re: 400whp
Well, I was reading earlier on a LS based forum that some guys were saying that a TPI engine has never hit 400rwhp with cam, heads, intake, bolt-on's and exhaust.
Old Mar 6, 2011 | 09:06 PM
88BlackZ-51's Avatar
Re: 400whp
dont know how it could make over 400rwhp with those long intake runners....
Old Mar 6, 2011 | 10:10 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 400whp
I think it's possible, but all the money (And a little luck.) that would be needed to do it, I think you are better off going with an LS swap.
Old Mar 7, 2011 | 11:12 PM
Re: 400whp
or put a miniram on....
Old Mar 9, 2011 | 02:25 AM
Re: 400whp
True! But then I dont think it could really be called a TPI, could it? HHHmmmm... Maybe.
86White_T/A305
Sep 21, 2015 05:28 PM
Xephy
Jan 4, 2014 09:59 AM
zraffz
Nov 22, 2012 10:24 AM
hartman
Nov 10, 2010 08:09 PM
Orr89RocZ
74
May 6, 2008 11:25 AM
