Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
This fitting/sensor is in my way on HSR swap...
Old Dec 18, 2010 | 02:14 PM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Please see attached pic at link below. Is this the oil pressure sensor/sender? The fitting that goes into the rear of the engine block is blocking my HSR intake manifold. I may need to get another one at the hardware store. Anyone else have this problem? Any suggestions? Thanks guys!!!
https://www.thirdgen.org/forums/atta...01218-1458.jpg
Old Dec 18, 2010 | 08:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: This fitting/sensor is in my way on HSR swap...
Get a 1/8" NPT male to female adapter to lift block fitting higher
Old Dec 18, 2010 | 09:00 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Seperate into 3 pieces. The part that goes into the block screw it on first. Then screw the second piece then the third piece and you're done.
Old Dec 19, 2010 | 01:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I had to enlarge the cutout in the HSR and grind some of the bottom of the rt angle fitting shown for clearance to do that
Old Dec 29, 2010 | 01:47 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
That's definitely 1986 stuff.
On some other applications, the large bell shaped sending unit is threaded into an adapter which is threaded into the side of the block on the vertical drivers side bellhousing flange, above the oil filter. That's another option for the SU and switch.
Later models had a combination SU / switch. If compatible with the gauges, that would be another way to clean things up.
Obviously those 2 options would require movement / lengthening of wiring or pigtail changes.
Old Jan 1, 2011 | 07:09 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
Use the new style combo oil pressure sender / fuel pump switch. Its a cleaner install. The sender comes in 1/8 or 1/4 npt size. I used the 1/8. The pigtail fits both. The center wire is for the oil gauge. The sender is for 0-80 psi gauges and more durable the old style. It was used on the 87 and newer engines. I updated in my montecarlo, after blowing out two of the old sending units. In fact, I am going to change the one on my iroc during my engine change.
Old Jan 31, 2011 | 10:10 PM
CamaroIROC88350's Avatar
HAHAHAHAHAA, It is definitely 1986 stuff babay!
bigjay89gta
Oct 15, 2015 08:04 AM
86z89iroc
Oct 5, 2015 01:04 PM
Gordonr1973
Sep 29, 2015 11:59 AM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
