Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
bigger runners?
Old Aug 4, 2011 | 09:56 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
bigger runners?
ok, i have a 91 bolt-on 350 tpi. I am thinking of another easy upgrade and the only thing left to do would be a set of bigger runners or a throttle body, but i don't think a tb will really make a difference. What type of increases/decreases have you all seen with adding bigger runners to your cars? Any noticable loss of low end torque? I have 273 gears,so i am concerned about losing low end torque.
Old Aug 4, 2011 | 11:43 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: bigger runners?
you wont lose much bottom end... but id spend the cash on a set of 3.42's or 3.73's .. then you really enjoy your car!
Old Aug 4, 2011 | 11:46 PM
Yager90IROC's Avatar
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Re: bigger runners?
the loss on the bottom end is pretty insignificant you wont notice it.
If you post in the TPI section you'll get a bit more help.
You should see some gains with runners especially if you port the plenum as well.
Old Aug 5, 2011 | 10:19 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: bigger runners?
Yeah, plenum is already ported and siamesed. Just wondering if the runners, preferrably the SLP runners were worth it. I do have th option of doing the rear swap. Guy wants $75 for a 342 rear end, drum to drum. Do you really think that going from a 273 to a 342 will be that big of a difference?
Old Aug 5, 2011 | 10:58 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Re: bigger runners?
That 2:73 to 3:42 rear end swap will be the biggest bang for the buck you will ever get for $75.00 you will "feel" 10x more seat of the pants difference than you ever will from bigger runners.
Old Aug 5, 2011 | 01:23 PM
Engine: Stock L98
Re: bigger runners?
The SLPs are worth it if you buy them used. I wouldn't pay $400 for them .
But they are the best due to the fact that they can be ported so thoroughly,
though out of the box they don't flow as good as other runners
Old Aug 5, 2011 | 03:22 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: bigger runners?
i would jump all over that 3.42 deal... you will feel a BIG increase in off the line torque... slp runners imo are only worth it if you can port them..
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sjorgens
Oct 1, 2015 07:54 PM
Royal_Z
Sep 30, 2015 08:45 PM
