Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
In-Tank Fuel Pump advice
Old Aug 14, 2011 | 02:05 PM
jaweiss's Avatar
Car: '91 Camaro RS
Engine: 383 Stoker
Transmission: Pro-Built 700R4
Axle/Gears: 3.42 Detroit Locker Posi
I'm going to be installing a FAST EZ-EFI system into my '91 Camaro for my 383 Stroker. I'm looking for a good quality in-tank pump to replace my factory pump. I want something that's going to get the job done for the 500hp but also isn't going to whine and scream like i've got a jumbo jet living in my gas tank. Does anyone have any suggestions on what to use?
Old Aug 14, 2011 | 03:48 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: In-Tank Fuel Pump advice
you may want to look at the walbro 340 or comparable aeromotive pump. they'll flow what you need for those demands and then some.
Old Aug 14, 2011 | 04:57 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
here ya go http://www.jegs.com/i/Aeromotive/027...0002/-1?CT=999
Old Aug 14, 2011 | 06:34 PM
jaweiss's Avatar
Car: '91 Camaro RS
Engine: 383 Stoker
Thanks!
Old Oct 15, 2011 | 04:32 PM
88gunmetalgta's Avatar
Originally Posted by scamaro355
Is this the right part number? the cross reference guide I found says to use the Walbro PN F20000169, which crosses to the Aeromotive 11140 pump.
Just want to get it right before I drop my tank.
Old Dec 16, 2011 | 06:50 AM
ilku's Avatar
Hi,
Does anybody know is this Aeromotive Stealth fuel pump 11140 suitable in tank assembly to my car Pontiac Firebird Trans Am GTA 1987? What is difference about this Aeromotive 11141 fuel pump exactly?
How much this aeromotive Stealt Pump could produce horse power?
Now I have Holley HLY-12-903 fuel pump in tank and it doesn't flow enough, that seems to be like almost WallBro fuel pump.
Now I have 520HP on rear wheel. My car is Paxton supercharged with 13PSI boost.
Does anyone have this Aeromotive fuel pump? Is this OK?
Thank You!
Ilku from Finland (sorry my english! =)
Old Dec 16, 2011 | 11:17 AM
I used the 11140 pump, but the 11142 one would have worked out a little better I think.
I can't say whether it would be enough fuel for you or not since I'm making much less power.
Old Dec 21, 2011 | 02:05 AM
ilku's Avatar
I have understood that 11142 is in line pump. So it doesn't work in line without fuel line modifications?
But this 11140 (in tank version) seems to give 30% more flow than Holley HLY-12-903 fuel pump.
If this fit in tank then this could be the solution.
Old Dec 21, 2011 | 02:22 AM
I don't think that's what it means. I think the outlet is lined up with the inlet, not that it's an "inline" pump.
Old Jan 1, 2012 | 10:15 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
I use a pump from a turbo Toyota Supra. It's not a direct bolt in, but can go in a third gen tank with a little fab work. It has proven to be a very reliable & super quiet pump. I had a 255 Walbro, and it couldn't keep up on the dyno. The engine would go lean at about 5000 rpm. The Toyota pump would supply enough to go to 6600 rpm, never ran it any higher than that. The engine is a LS1 that made 420 RWHP. Rock Auto has the pump, part #9500155.
Old Aug 6, 2012 | 07:45 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Use a kenne bell boost a pump
Old Aug 9, 2012 | 09:00 PM
oldtimer's Avatar
As already mentioned, the Toyota Supra pump is a good choice. I tossed a Walbro in the trash and installed the Supra Turbo pump in my 87 GN. No problem with fuel delivery volume or pressure. A near drop in. Will just fit in the hole, and have a non stock sock filter set up. Not rocket science. Get a hot wire kit, as the factory wiring is too light to power the big pump! Racetronix has it. Thanks, Oldtimer.
Old Aug 10, 2012 | 04:27 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Aeromotive makes a good one they did a shoot out between the 3 pumps. Supra one is quite a bit bigger than the walbro and areomotive.With the new aeromotive pump why even bother with fitting that supra pump in your sender. At 500 hp the walbro is still capable and then some. Areomotive and walbro are plug and play, denso is not. I never understood the hot wire kit to the sender. Since you cant even upgrade the gauge of the sender to pump wires in the tank I dont understand 10-12 gauge feed with a 16 gauge pump feed wire. You really dont start dropping volts until you get over 15 feet. You can make your own hot wire kit for a couple of bucks.Use the pump turn on wire from your fast to switch a 5 dollar relay. Run power from battery or back of altenator to feed 12v on relay.Feed pump with relay when fast ecu switches the relay on. Cheaper than the racetronix. I would definatly fuse 12v to relay though. Here is that link to pump shootout:
http://realstreetperformance.com/sto...on-test-5.html
Take care.
Old Aug 10, 2012 | 04:50 PM
I've never understood those $100+ boost a pump wiring kits either. I mean, I know there's some voltage drop from the relay to the pump, and I know some of them actually up the voltage to the pump, but it still seems like a band aid to me. I'll be using a Bosch relay and some 12ga wire when I relocate the battery to the back though. As I said before, I'm happy with my aeromotive 340.
Old Aug 12, 2012 | 03:09 PM
mine>yours's Avatar
i have a 91 fbird with a new 350 bottom end. rebuilt ho 305 heads and a 305 tbi system 700r trans and 3.73 rear end. running 93 oct. how much hp power would one say i can make with this? and how do i start my own thread? kinda new to this site
Old Aug 12, 2012 | 03:41 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Really not much more than stock if you are running the factory cam and tune. Prob 225 @ the crank.
Old Aug 12, 2012 | 06:34 PM
oldtimer's Avatar
The Racetronix set up replaces the wiring to the pump, including the bulkhead connector. Not a splice job down to 16 guage wiring. My experience with the Buick GN set up wasn't bad. On those cars, some folks were having problems with the big pumps overheating and burning the stock wiring. Poke your head in at the TurboBuick.com site and check it out. Tons of info, and debate, on the fuel pump issue. Oldtimer.
Glowsock
Jul 24, 2025 03:15 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
