Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
FIRST bellows?
Old Oct 25, 2011 | 10:27 PM
weaselbeak's Avatar
FIRST bellows?
Hello for those of you running a FIRST intake with MAF what did you do for the air bellows from the MAF to the Throttle body of the FIRST? I have an '87 vette and the throttle body on the FIRST is a bit larger than my old one. IIRC 72mm inside and a shade over 100mm on the outside.
Old Oct 29, 2011 | 07:01 PM
gbayfisher's Avatar
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Re: FIRST bellows?
I used 3 and 4 inch silicone tubing. It's the same tubing used for power adders.
I am pretty sure the stock tube will fit on the FIRST tb, its a tight fit, and a different shape, but can be squeezed over the opening.
squiggy2
Aug 9, 2015 09:30 PM
z91bowtie1
May 19, 2004 10:04 AM
1bdbrd
Mar 28, 2004 06:13 PM
1EasyRider
Nov 4, 2003 05:06 PM
1MeanZ
Oct 16, 2002 11:31 AM
