Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Alternative FPR's?
Old May 12, 2012 | 09:43 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Alternative FPR's?
for the HSR fuel rails?
Aside from the Holley that comes with there kit, I did put on a Kirban and quite honestly haven't been all that happy with it. Seems to always leak a bit at the diaphram. I've replace it 3 times and the same problem. Are there any other good quality ones out that that fit the HSR?
Old May 13, 2012 | 12:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Alternative FPR's?
Plug the stock reg hole ( or use 2 RH rails) and fit any aftermarket reg to the end of the rail
My VIC E setup shown but I did the same on my HSR
Old May 13, 2012 | 08:10 PM
slrvette's Avatar
Car: Corvette
thats a good idea. I don't have 2 RH rails so what could I use to plug the stock hole?
Old May 15, 2012 | 10:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Take the rail off and have the end chopped off and re-threaded for 3/8 NPT or -6an. I had a set of -8an rails set up like the HSR rails and I just had then cut down and rethreaded. Works fine and save an inch or two on either side. I think I actually used that same AFPR.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
Lmancha96
Sep 25, 2015 08:11 PM
