HSR Dead Injector
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
HSR Dead Injector
Need some help! I have 89 camaro with HSR intake with SVO 24lbs injectors. It starts and idels but number 1 injector is dead. Have 15 ohms on all injectors but only 0.59 Volts while cranking the car. Should i have 12 volts? Could be ground issue somewhere I removed all emissions from the harness.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HSR Dead Injector
Dead as in doesn't work or dead as in low ohms?
One bad injector will take out the whole inj bank on one side of engine
Injector fuze's appear fine, no volts with just the key on. Replaced the dead injector and fires right up, running all 8. But only have voltage while cranking the motor, throttle seams to rev easy.
Thanks, I used a new set of injectors number 1 cylinder never worked. Until it was replaced, now it runs better. What im wondering if you have 12v at the injector with key on, why mine has Ov with key on but runs.
Does the car run well? Will it rev up? What are you using for a ground on your multimeter? Did you check both pins for power? (Maybe youre probing the ground looking for power.)
Thanks, got it figured out. Was having some operator error with my meter.
