Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Hurricane EFI manifold too big?
Old Sep 6, 2012 | 02:26 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Engine: ~400hp Vortec 355ci
Transmission: T56 6-speed
Axle/Gears: 4.10 Moser 8.5" 10-bolt
I've got a 355 with an RPM Airgap and carb right now with Vortecs. I'm converting it to EFI and planning to build a 383 in the future. I already bought some AFR 195s that I'm going to put on the 355 for the time being, so I need a new intake anyway and might as well do it all in one shot for the 355 and worry about the 383 later.
The Hurricane EFI manifold looks huge. Am I going to lose torque vs the dual plane carb setup at this displacement? Same question goes for the Edelbrock Victor E and Accel manifolds I've been looking at...but they don't look as massive as the Hurricane.
Old Sep 6, 2012 | 02:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Hurricane EFI manifold too big?
With efi i honestly dont think you will lose mid range or low end like you do on some carbed single plane setups. But the cam is gonna play a strong role here. Tighter lsa will bring trq back in
Old Sep 6, 2012 | 03:27 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Cam in the current 355 is a Comp 280H flat tappet (230/230 .480/.480 110). I am going with a new roller on the 383 build...and a tighter LSA does sound really nice. haha
So there should be no issues with a speed density tune either?
Old Sep 7, 2012 | 12:56 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Worry about runner length and port match. Not so much the visual big factor; it's just a plenum after all.
Oh and don't over-cam it. Aim for power under the curve, not peak numbers.
Old Sep 7, 2012 | 02:38 AM
77nomad's Avatar
Woody! I'm here on recon too! I have been reading that the single plane disadvantages go right out the window with EFI. There is a sticky above that has good info on the single plane intakes.
Old Sep 7, 2012 | 06:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I have run mine on 2 setups, both 400" motors in my turbo car but part throttle driving it acts like any other.
One setup was mild, just a 195cc head and 233 cam. Very torquey. Drove great despite low comp and 2.73 gears! No real loss of power that i could feel with the single plane. Felt no diff than the hsr on my high comp 383.
Current setup is huge 245cc heads and big 246 deg cam. Figured id see a lazy bottom with this heads cam setup. Nope. Feels even stronger than before.
Single plane willl give broad curve like hsr since runners are somewhat similar in length.
Old Sep 7, 2012 | 08:12 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey!
I'm running that exact intake because my Holley wouldn't cover the 1206 ports of the AFR 210 heads.
The intake looks huge due to the air gap design. It's 6" tall, and the runners are a little longer than a miniram.
The Victor is actually smaller, shorter runner, which technically would mean it would be for higher up in the powerband.
Single vs dual doesn't matter on a DRY application like port EFI, since your not relying on a vac signal to the carb. However runner length does matter for effective powerband.
-- Joe
Old Sep 7, 2012 | 09:20 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Well, yeah...huge as in the runners look massive. And I know huge runners on heads mean less torque. Maybe EFI is the cure?
Old Sep 9, 2012 | 10:58 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I haven't noticed any torque loss with the single plane. In my opinion, it's right there with the MiniRam although the runners are slightly longer with the single plane and therefore build better midrange. Another benefit is the air distribution. Very easy to tune and a very stable idle. This was not the case with the MiniRam. Hood clearance is not a problem even using a 1" carb spacer, 1/2" air cleaner spacer and Spectre cold air kit.
BTW - I bent the crank in my 406 and am pulling the motor and selling the intake if interested.
Attached Thumbnails Hurricane EFI manifold too big?-dscn0724.jpg   Hurricane EFI manifold too big?-dscn0728.jpg
Old Sep 9, 2012 | 04:25 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Yeah, definitely. Let me know how much.
Old Sep 9, 2012 | 06:50 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
I listed in the classifieds.
https://www.thirdgen.org/forums/engi...ml#post5374558
Old Sep 15, 2012 | 05:43 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
they have 2 size of the Hurricane intakes
the Hurricane, and the super Hurricane (for 420cid and up small blocks)
im going to swap my accel proram out for one of the super Hurricane intakes (can even get it polished) for less then the accel.
Old Sep 15, 2012 | 09:10 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I don't think the regular hurricane comes in an EFI ready version. Both "Coast Performance" and "KMJ" usually have good prices on these. The one I used on My cousins car was polished, and I noticed that the prices for the polished version can vary by well over 100.00.
The airgap under the plenum is quite big and you should be able to hide most of your wiring under the plenum.
Old Sep 16, 2012 | 02:19 PM
yes the super Hurricane is all set up for EFI. you get there rail set, for like $229, it has all the lines fittings and even a EFI reg. (i heve mine) but even from summit all this set up runs polished for just under/at $560.
JUST THE ACCEL PRORAM with rails ran $505 when i paid for it..
just want to ask pp ON monday a few things..
Old Sep 16, 2012 | 08:00 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by articwhiteZ
yes the super Hurricane is all set up for EFI. you but there rail set for like $229 it has all the lines fittings and even a EFI reg. (i heve mine) but even from summit all this set up runs polished for just under/at $660.
Just use the procomp rail set:
http://www.ebay.com/itm/170803053933...84.m1423.l2649
The super hurricane and procomp is the same casting. The manifold pictured above is actually the procomp, which retails for $168.
-- Joe
Old Sep 16, 2012 | 08:42 PM
-- Joe
going to the procompoverstock ebay sight and looking up
the lager runner intake (that can be taken out to a felpro 1207)
gasket in the polished finnish gets me this part #PC22038
and runs over $300
for us guys doing over 420cid eng
from procomps site
CHEVY SB SHOOTOUT PRO 1957-95 W/INJ PORTS MANIFOLD POLISHED
E-mail this product to a friend
These Shootout Pro Manifolds feature a larger plenum and bigger runners than the standard Shootout Manifolds.
It was designed specifically for the new range of large cubic inch small blocks and works best on engines over 400 cubic inches.
On the 400+ cu. in. small blocks now available there is no other manifold that will produce the power and torque.
It is also available machined for injectors.
Use our Complete Fuel Rail Kit with this manifold when set up for fuel injection.
This manifold can be ported out to a Fel-Pro 1207 gasket.
SKU:PC22038Dimensions:23.000x11.000x8.000Weight:17.00
$317
Old Sep 16, 2012 | 10:17 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
and runs over $300
http://www.ebay.com/itm/SBC-CHEVY-Hi...6cd16c&vxp=mtr
PC #2039 ($168)
http://www.ebay.com/itm/SBC-Chevy-Hi...2cdd04&vxp=mtr
PC #2038 ($199)
The only difference is polish vs not. I'm running the #2038 on my 412 sbc.
-- Joe
Old Sep 17, 2012 | 07:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Seems like a good bang for the buck. My non polished victor was a touch over 300 bucks but it can be ported to 1207 easily. My cam guy doesnt seem to like the victor single planes but they do seem to work from the cars i have seen run them.
Old Sep 18, 2012 | 10:04 AM
woody80z28's Avatar
Car: 80 Camaro Z28
Has anyone run one on a smaller displacement engine like a 355 or 383?
Old Sep 18, 2012 | 03:29 PM
project89's Avatar
i will be able to give feedback on a 355 here soon i ordered one and the fuel rail kit
i just havent decided if im going with a 4bbl tb or an elbow and lsx tb
its going on my 9.2-1 cr 355 im going to pull the turbos off when i first put it on to get the 20-100kpa part of my ve tables dialed in
Old Sep 20, 2012 | 01:10 PM
monte0185's Avatar
Car: 1991 Camaro Z28
Engine: 383
Transmission: tci 700r4
Axle/Gears: 373
Same here but itll be going on my supercharged 383 with 9.0-1CR. Hoping itll do alot better than my current TPI setup which makes great bottom end and nothing after about 4800.
On a side note anyone running one of these what are you doing for the back cooling ports? Thought i might use mine make things run a bit cooler??
Old Sep 20, 2012 | 01:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I didnt do anything on mine for extra cooling but considering it. Would drill and epoxy some nipple fittings there and run heater hose to it from somewhere, either off pump or whatever
Old Sep 20, 2012 | 02:48 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by monte0185
Hoping itll do alot better than my current TPI setup which makes great bottom end and nothing after about 4800...
What are your cam specs...?
Old Sep 20, 2012 | 04:28 PM
project89's Avatar
+1
with the summit 224 cam mine dosent fall off till around 5,200 with the turbos
Old Sep 20, 2012 | 07:47 PM
88gunmetalgta's Avatar
What throttle body is this? It looks like you almost could have gotten away without the carb spacer.
Old Sep 20, 2012 | 09:40 PM
ya know i like the polished look..so i can look past its made in China Stamp! but at the same time the ports have to be cleaned up to even fit a felpro Gasket...(saw one today)
and my US made intake, Looks like it was made by felpro...for the fit and finnish of the ports...
but i do like the looks!
1. no vac ports..Not a 1.
2. needs port clean up to work with felpro gaskets (if you care)
3. big made in China stamp on bottom (cant see it when on car)
4. ?
Old Sep 21, 2012 | 05:05 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
4. ?
Mine fit a felpro 1206 almost perfectly... The only thing I cleaned up was a little casting flash inside the runner.
The radius of the corners is not the same as the felpro 1206, but neither is my AFR 210 heads. If you hot it out to perfectly match the 1206, now you have to grind your heads too..
-- Joe
Old Sep 21, 2012 | 12:52 PM
-- Joe
Per..AFR...Do Not Open Up your Ports to fit the 1206 Gaskets
The smallest AFR heads i use are the 220's.and they fit the 1206 with out having to do anything. the intake i have now needs almost nothing, just a touch if anything. no casting to clean up
all that work was done be the Maker...helps out alot
below is what the felpro 1206 gasket fits like..intake gasket can move down maby 3mm.at time of install.. needs no work to speek of.
below.what mine looks like at this time (world prodcs. Motown /accel ProRam) SUMMIT $505.95..PRICE DROPPED TO $489.95 I seen. only 1 Vac port..the uper plenum. fits my elbow. almost 1 to 1.
might just Pick one of the polished intakes up. at $200 Thats cheap...to do a side by side. and pick the one i like..and send the other one, i dont like, back..
Old Sep 21, 2012 | 01:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats my afr 195 which is not exactly 1205. I port matched my victor e to afr's port since the vic e is abit smaller out box. That gasket is a 1207 which is what my new heads are. Vic e has been ported to that size. Tons of material removed but plenty of room to do so
Old Sep 21, 2012 | 01:32 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Here is a 1206 felpro over the chinese intake. Fit is about the same as yours, maybe a hair more material in the radius.
-- Joe
Old Sep 21, 2012 | 01:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Nice to see intakes available in 1206 from factory. Less work to do. If you are doing a mild 195cc head or smaller perhaps the victor is best to start with since its just smaller than 1205 and be a better match
woody80z28's Avatar
Car: 80 Camaro Z28
How is the port match from the AFR 195s to the Hurricane EFI intake? I have heard that head ports bigger than the intake are acceptable, but intake ports bigger than the head ports are a big no no.
Old Sep 21, 2012 | 01:51 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The hurricane is bigger than the 195 unless you get comp ports on the 195.. So it won't match.
Best with a victor, or holley as Orr said.
-- Joe
Old Sep 21, 2012 | 03:54 PM
yes the US Motown intake will take no work, just bolt it on. if you want to use 1206 felpro gaskets.
all the runners have no casting flash/crud
nice and smooth.But for over $400 what would you expect..lol
has for the Chinese intake the ports look to be Diff Sizes also..or is it Just me.
yes that could be fixed also.(less work then Polishing!!)lol
below is what the felpro 1206 gasket looks like on my AFR 220 Eliminator Heads
100% CNC worked.
the gaskets are a bit small top and bottom. It's a simple fix. and i think the 1207 gasket might be a bit Big. (ill grab a set and see)
this is has close, in the out of the box bolt together, that Iv seen. for the ricky race intakes and heads..Now just add 15lbs of intercooled boost! and the big sticky Tires, and you could have a OK street car!
Old Sep 21, 2012 | 05:15 PM
woody80z28's Avatar
Car: 80 Camaro Z28
-- Joe
Funny you mention that. I got the 195s used and they are supposedly comp ports, but a call to AFR said there is no way to be sure by decoding them. I guess I'll have to grab a gasket and see.
Old Sep 21, 2012 | 06:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
They would have a part number on them.... Else check valve diameter. Comps got larger intake valves than regular ones. What year heads tho? Not new eliminators?
Old Sep 21, 2012 | 10:03 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Nope. Not Eliminators. 91038 195 HV is what is on the head face. What would be the intake valve diameter if they are comp ports?
Old Sep 22, 2012 | 07:34 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Those are the old odd 195s. If I recall, they had fitment issues with some manifolds because the port is raised. I know early HSR's didn't cover the port, and I suspect the older holley singleplanes would have the same issue.
What did you pay for them ?
The 195 eliminators outflow the old 195s with comp ports, and the 195 elims with comp ports flow like a 210 head. If I recall, I think the old 195s peak at like 260cfm.
-- Joe
Old Sep 22, 2012 | 08:28 AM
woody80z28's Avatar
Car: 80 Camaro Z28
-- Joe
I probably paid too much at $900. I assumed they were Eliminators because the engine I bought them off had less than 1k on it. However, I'm the third owner of the heads. The port issue has me a little worried too, because these have already been surfaced and I cc'd them at 60cc.
Old Sep 22, 2012 | 12:12 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You might have paid too much. I sell Elims in for around $1350.. But if they work they are still better than most off the sheld alum heads in that size, so maybe it wasn't such a bad deal.
Can you figure out how tall the ports are from the bolt centerline?
What do they actually measure for h x w ?
-- Joe
Old Sep 26, 2012 | 04:54 PM
woody80z28's Avatar
Car: 80 Camaro Z28
-- Joe
The intake ports are about 1.185 wide by 2.075 high right at the gasket face. About 1.052 x 2.075 a little ways in to the port where the wall comes in. Valves appear to be 2.02/1.60 which cant be good. I can pull them out to get a better measurement if needed. But that might be all you need already...
Old Sep 26, 2012 | 06:40 PM
  #42
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Eliminators would have 2.05 intake valves. Old 190-195's I think have 2.02"
Old Oct 4, 2012 | 09:10 AM
  #43
woody80z28's Avatar
Car: 80 Camaro Z28
Yeah, I know they are not Eliminators. They have an A on the side and not an AFR.
anesthes, any thoughts on the port measurements?
I like the clean look of the Hurricane manifold with no logo and the tall runners, but if it will be too much for these heads I'll go with an Accel setup I found used for a good price.
Old Oct 4, 2012 | 09:28 AM
  #44
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You would have to open them up quite a bit for the hurricane, or your air is going to be hitting a wall. They are just under a 1205 port.
The "hurricane" manifold sold on ebay is 99.9% sure to be a procomp casting, and will say so on the front. (see image). They are same manifold, made in the same plant, some go to procomp, some go to pro products.
-- Joe
Old Oct 4, 2012 | 09:32 AM
  #45
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah thats under 1205 by slight margin. Hurricane can work but there would be a step. May hurt performance by a slight margin. Hard to say. I wouldnt touch the heads unless you send them out to be ported completely.
Old Oct 4, 2012 | 09:50 AM
  #46
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
He's probably better off picking up a holley or edelbrock intake with the smaller 1204 ports, and hogging them out to match the heads.
-- Joe
Old Oct 4, 2012 | 09:51 AM
  #47
Curious, do you have any pictures of inside the bowls Woody...?
Old Oct 4, 2012 | 10:04 AM
  #48
woody80z28's Avatar
Car: 80 Camaro Z28
Here are the bowls:
I put them up for sale to see if I get any interest.
Old Oct 4, 2012 | 10:06 AM
  #49
woody80z28's Avatar
Car: 80 Camaro Z28
-- Joe
How about the port sizes on the Accel or Motown EFI intakes? I've been searching used setups and I found one of each for good deals. The Accel comes with the DFI computer & harness and the Motown comes with no electronics or wiring. But for either one I can wire them up with standard OBD1 stuff.
Old Oct 4, 2012 | 10:08 AM
  #50
Here are the bowls...
No, I meant if you had any with the valves removed, possibly...?
