Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
iac passage noise
Old Nov 23, 2012 | 03:51 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
iac passage noise
My holley 4bbl, the iac passage at idle whines so loud it sounds like a big roots blower. If I give it a little throttle the air goes to the throttle blades and the sound goes away.
Anyone ever experience this harmonic noise from the iac passage on a 4bbl throttle body? When I say it's loud I mean, can be heard in the next town over..
-- Joe
Old Nov 23, 2012 | 08:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: iac passage noise
Had the same issue with a BBK 58mm T-body. Its the angle of the blades and the way the air goes between it and the bore housing.
I put a small groove in the edge of the blade with a file and it helped a little bit.
Old Nov 23, 2012 | 09:02 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think mine is actually coming out of the iac passage as opposed to the throttle blades, but I could be wrong. I'll tinker more tomorrow.
Either way, it's stupid loud.
-- Joe
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
