Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Supperram Sandrail
Old Jan 25, 2014 | 12:03 AM
WejaZ28's Avatar
Supperram Sandrail
first post, thanks for looking. all my searches bring me here, so thought someone here could help me.
Equipment: Sandrail with an 02' ZZ4 with Supperram, Accel DFI
Cause:Fuel line disintegrated in fuel tank. clogged filter, then injectors. took apart, had 32lb injectors rebuilt. new pump , lines and filters. 43lbs fuel pressure no vacuum.
Problem: Cold start, engine will not hold idle without help from my foot on pedal. if I unplug IAC and raise base idle, it will settle at about 1200. no lower, even if screw is backed out and not touching butterfly tab. If i plug the IAC back in, it will stall again in a little while and not idle unless I do the above.
Questions:
1. Shouldn't the IAC raise the idle, not kill the engine?
2. Can't find initial setup for IAC using Accel computer. everything references the stock GM computer. I have no ALDL connector.
Thank you for any help.
Old Jan 25, 2014 | 12:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Supperram Sandrail
Send a pm to member efi guy, is this a gen 7 dfi ?
Old Jan 25, 2014 | 09:45 AM
WejaZ28's Avatar
Not sure, It would have been what was available in 02'.
Old Jan 27, 2014 | 10:59 AM
efiguy's Avatar
Yes idle should stabilize with the IAC. Sounds like it's not wired right.
Gen 7 DFI box will be black, Gen 6 is silver. Which one do you have? If it's an '02 you could have a Gen 6. There were still some of those around new at that time.
vladicore
May 1, 2005 01:49 PM
Larry Dunlap
Nov 14, 2002 07:41 AM
Shorty Cox
Sep 16, 2002 09:29 AM
Shorty Cox
Sep 6, 2002 02:12 AM
