Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Ram jet 350??
Old Mar 3, 2014 | 08:14 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Ram jet 350??
Didn't know where to put this so I figured I would start here. I am thinking about purchasing a ram jet crate motor for a project I am working on. Has anyone used one? The big question I have is it tunable or pretuned?
Old Mar 3, 2014 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Ram jet 350??
If it doesn't come with a computer and wiring harness you have to get a tune on your existing computer to suit it
Old Mar 4, 2014 | 07:43 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: Ram jet 350??
You can get it with or without a controller.The MEFI4 controller that comes with it can not be accessed for tuning except by very few ppl.The tuning that comes with the controller leaves a lot of power on the table.It is tuned for the Ramjet 350,so,if you make any changes such as cam,etc,it will need to be retuned.Your best bet is to buy the setup w/o the controller & use a GM 0411 controller from a 2000 GM van that still ran the L31 engine.The black box PCM for 96/99 Vortecs will work as well.
Old Mar 4, 2014 | 08:11 AM
seiplentz's Avatar
Car: 85 Z28
Re: Ram jet 350??
Thanks for the input on that. I was going to get it with the MEFI4 controller. We were looking for drop in fuel injected motor that doesnt require much hassle and this seems to be the only one available. I did find there is software available the the MEFI that allows tuning. But maybe swapping to the 411 PCM may be the way to go.
Old Mar 4, 2014 | 10:04 AM
jokerZ71's Avatar
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: Ram jet 350??
EFI connection sells a new L31 w/ Ramjet & 0411 controller already setup to run.It's just a stock L31 w/o the Ranjet cam & 1.6 roller rockers.It includes everything you need for about the same price as the Ramjet 350.
Old Mar 5, 2014 | 08:29 PM
efiguy's Avatar
Re: Ram jet 350??
MEFI4 is still very limited as compared to virtually every other aftermarket controller. Night and day with the right setup.
The El Camino in this vid had a MEFI4 that was "retuned" 3 times, still ran like crap.
As mentioned, it leaves a lot to be desired.
Old Apr 26, 2014 | 10:45 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Re: Ram jet 350 -mine is running on EZ-EFI 2.0
I just converted it to EZ EFI 2.0 since Dec 2013. runs better than ever. I'vehad it about 10 years and I've run it with the MEFI-3 and also by burning my own chips using a 730 ECM. Don't bother with any of that....just go with EZ EFI 2.0.....mine runs better than ever.....most of it plugged into the regular sensors that it came with.
However - if I was doing an engine mod today I'd probably just find a LS engine. I like my RamJet 350, but for all that trouble I think you'd be better off with an LS engine....unless you want to stick with Old School SBC.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
