Fuel pressure issue
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Fuel pressure issue
i am getting erratic fuel pressure. the fuel pressure gauge is bouncing between 50-60lbs rapidly, i would like pressure set to 50lb. i am running a HSR, 26lb injectors and holley afpr. i had the vacuum line disconnected and connected on the regulator and it doesnt make a difference. reving up doesnt help either and the only time stays even is when i let off the throttle for a split second.
im using a harbor freight gauge it is not a liquid filled gauge, im thinking that could be the issue. what do you think the issue could be?
Re: Fuel pressure issue
took guage and lines appart blew them out and cleaned them.... works perfectly now... idk
mdtoren
Aug 16, 2015 05:45 PM
