Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel rail issue...
Old May 15, 2014 | 02:23 PM
Ronny's Avatar
Fuel rail issue...
I have a 2013 edition Motown single plane intake.
I purchased Edelbrock rails that are advertised for Victor E SBC.
After I matched them up visually to intake it is clear they are close but obviously different.
FIC says injectors are tolerant to small differences in fitment.
I am not sure what to do as other rails may not be better. I diont see Motown rails anywhere. china rails are $80! Might fit!
Also the Edelbrock universal 4B TB linkage rubs on the rail w/o the cable attached. It is all on the bench right now. I need to shave .50 inch off the top of intake to provide .50 inch clearance to hood. That will make it worse!
ps Jegs told me I need blank fuel rails machined to fit intake?
comments?
UPDATE /16/14
I measured the intake and rails in injector placcement.
Only significant difference is that lenght from injector 1 to injector 7 shows the rails are about .12 inches off. However my measurement s may be a buiit off as well. LOL That difference appears to be spread over the 4 injector placements. May be just fine.
I found that the butterfly shaft nut in fact does not rub. I plan on shaving .50 inch off the top of mani so that will place the interfearance area at center above the nut. That was good luck.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
