Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
4150 Intake and Throttle Body
Old Jul 22, 2014 | 03:37 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
All of you guys running a 4 barrel style EFI intake with a 4150 style throttle body. Which throttle body adapts over easiest to the TPI wiring and throttle and trans Cable? Also, is there a preferance to which EFI 4150 style intake that is sticking out above the others?
Old Jul 22, 2014 | 08:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 4150 Intake and Throttle Body
I am using the Accel throttle body and I feel it is an easy switch. Accel gives you an IAC connector converter so you can use the stock TPI IAC connector. The TPS is the stock connector. IAC and CLT sensors are both TPI sensors. You will need to use new/different throttle and transmission cables. I was able to use the el cheapo run of the mill universal braided MR gasket throttle cable. I have a manual so no advice there.
Old Jul 23, 2014 | 09:28 AM
abray1's Avatar
So electrically there is no real problems but you do have to change the throttle cable and detent cable for the 700R4? Do you run a regular air cleaner?
Old Jul 23, 2014 | 07:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I run an open air element with one of those extreme flow lids. It does suck warm-hot air but the only other option that looks good is one of the carb hats meant for blown carb setups. Those hats are usually $100 and I am not in dire need of a few extra horsepower. Sensors' conectors for these style efi for GM are easily rewired if you need to.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
