ANYONE USE LT1 SUPERRAM PLENUM ON L98?
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Hello. I bought a lt1 superram with an accel l98 style lower and runners to put on my l98. This is the shorter plenum for the 93 97 cars. Has anyone used these on a thirdgen before? Thanks Chris
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Re: ANYONE USE LT1 SUPERRAM PLENUM ON L98?
Yup , thats what i have. it all fits except the belt tension pulley up front needs a bit of " work" from what i know it fits with no trimming near the wiper motor,
but it gives up a few hp at the red line, over the non LT1 version,
I have the same combo as you for the most part, afr 180 superram lpe 219 cam headers 3000 stall 3.23 gears. Putting motor in in a few weeks Have you ever run the car or dynoed it? I'm wondering about real world times, and also what cam did you use? Thanks Chris
Car: 1992 GTA
Engine: running
Axle/Gears: both
Chris ,
i suggest you check out www.dynamicefi.com
I run the EBL P4 on my GTA , it is a great system with great support, it will make that combo of yours run great.
[CA] AS&M / TPIS Runners
QuickStyle
Dec 7, 2015 09:25 PM
[TX] LT1 std flywheel 40$
zman1969
Nov 8, 2015 09:51 PM
