Fuel Sending Unit - What did you do?
Car: 84 MSE TransAm #22
Engine: SBC 350 +.060, Holley Sniper EFI
Transmission: 1991 T5 WC
Axle/Gears: Eaton TrueTrac in Dana44 case- 3.31
I am currently in the process of switching from factory carb to the Holley Sniper EFI. Since my ’84 TA did not have the EFI tank I have purchased a new unit for an ’89 5.7L and the sending unit to install the intake fuel pump. I also purchased the Walbro pump kit 5CA400HP (255ltr) and 20' of Earls 3/8” Vapor Guard EFI hose & clamps. I will be using the existing 3/8" stock hard line (orig feed line) for the return... my concern is with the sending unit return line is only 5/16”. I have heard that the return line should be an equal size as the inlet or there would/could be pressure buildup especially when the tank is full (since that return goes to the bottom of the tank).
After looking at the sending unit I see that there is a 3/8” line for the tank pressure valve ( the one that is mounted above the axle). I was thinking of converting this with an added 3/8” hard tube to the bottom of the tank and using the smaller diameter vapor line (after removing the rollover check valve) for the pressure valve. This of course would mean that the vapor canister would need to be unused/removed and the 5/16” sending unit return line would need to be capped off. (Note - all emission hardware has been removed due to damaged & inoperable components and connectors over its 34 years of operation). This is not a daily driver and is will be used for fun & show.
Your thoughts?
Your thoughts?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fuel Sending Unit - What did you do?
edit: removed post,... mine was not an aftermarket set-up !
Was yours stock? This unit is a stock setup except for the Walbro 255 ltr pump and 3/8" high pressure hose to the EFI. Really trying to find out if anyone has had success/issues with the stock EFI sending units as I would rather take care of this now rather than drop the tank again...PITA
I swapped from a factory Carb in an 84 to an LT1 and used a stock TPI sending unit, stock TPI fuel pump, and stock TPI fuel lines...... G-T-G !
Donald Croes
Jul 3, 2016 12:19 PM
mikesz1984
Alternative Port EFI Intakes
Sep 21, 2009 01:34 PM
Jeremysyty
Aug 24, 2008 03:07 PM
Larry Dunlap
Dec 31, 2004 07:58 PM
