Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Pro-Flo XT on a firebird?
Old Aug 28, 2018 | 07:27 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I have looked and looked has anyone tried one on a Firebird?
Old Sep 4, 2018 | 03:10 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Re: Pro-Flo XT on a firebird?
also hoping to find out about this. Some internet searching and it seems like people have got it to fit under a stock C4 hood so I think there's hope.
Old Sep 4, 2018 | 09:11 PM
zman1969's Avatar
Car: 90 Formula 350
I cant believe no one has tried seeing if this fits yet!! seeing how TPI parts are not being made anymore we need an affordable manifold that fits and makes some good power
I found this comparison to a Super ram
looks like Pro-Flow is taller by a smidge , can anyone see if SR has any more room under hood?
Old Sep 5, 2018 | 12:41 AM
GTA1990's Avatar
Car: 1991 Trans Am
interesting; looks like if there is an issue it will be with the throttle body. Can't seem to find the post but a member had some interference under a trans am hood (later vented type) but apparently this was because of poly engine mounts.
Also a guy on youtube named zz3astro (I believe he's on here aswell) that has/ had a pro flo in his Iroc but not sure if he experienced any interference
Old Sep 5, 2018 | 01:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Not a great comparison. The sr has a oil try on it raising it up in the image.
Old Sep 5, 2018 | 02:17 PM
zman1969's Avatar
Car: 90 Formula 350
True, that's obvious, at least I noticed. I did find this thread: Proflow- Superram showdown
I did read this in the article: "The Pro-Flo XT is 9.05 inches high at the tallest point-the throttle body flange-making it taller than the SuperRam."
Is S/R as tall as stock TPI? and how much room is available I am not putting some silly A/M hood on to fit an intake
So the question begs- is it too tall?
Edit: I also found this a corvette forum member posted: "The SuperRam has a height of 9 3/8" from the bottom of the intake to the top of hte plenum- thus it should fit fine- when you measure, remember that its 9 3/8" even at the front of the unit
Hmm
Old Sep 5, 2018 | 02:26 PM
Engine: Lb9
Transmission: M20
I think the sr and stock tpi are the same height. I took this picture awhile back to show the comparison.
Old Sep 5, 2018 | 03:45 PM
zman1969's Avatar
Car: 90 Formula 350
So who has a S/R equipped Firebird that can check for hood clearance?
So i went to Edlebrocks website and found this info:
Front Maximum Height9.200 in
AND
Availability NoteDiscontinued
So maybe I need to find one before they're gone
92Z28ZO31LE
17
May 5, 2009 08:42 AM
377Z
Sep 30, 2003 08:15 AM
I ROCK
Aftermarket Product Review
Aug 2, 2001 04:21 PM
BlackBird305
Dec 29, 2000 12:37 PM
88 GTA
Sep 18, 2000 08:40 AM
