Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Need help
Old Oct 9, 2019 | 04:24 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Need help
I sent from a 305 nodded tpi 5 speed to a 383 with a t56 and hsr intake
My question is I lost alot of low end tq going from you to hsr
And honestly I'm thinking about switch back to tpi
It's a street car 99% and me recujg it part 4500 is badly happens
I can't drive fast around here and I have horrible stock new brakes
Should I go back to tpi or keep my hsr
I paid alot of money for it
Am I nuts
Old Oct 20, 2019 | 11:06 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Need help
Keep the hsr and work on your tune. TPI is way too small for a 383
Old Oct 20, 2019 | 06:17 PM
BadSS's Avatar
Re: Need help
Am I nuts
Did you ever have the TPI on the 383? As already indicated the HSR needs a tune - for one a lot more timing than the stock program. A HSR and 383 should have plenty of torque and more than the 305 TPI unless you went way too big on the cam.
Old Oct 29, 2019 | 04:52 PM
bensbaby's Avatar
Engine: 383 built
Re: Need help
I have a Chevy performance lt1 hot cam
Not the biggest cam at all
If anything it's small
I have a custom chip to
I know I think I'm just gonna keep what I got
Old Oct 30, 2019 | 06:36 AM
ULTM8Z's Avatar
Re: Need help
Losing some torque with the HSR is probably expected. But it shouldn't feel slow.... my 350 with a Miniram is definitely not lacking for torque.... probably even shorter runners than the HSR.
I agree that probably your tune is off.
Also what axle ratio are you running?
lowbird
Jul 23, 2011 12:05 AM
89IROCZZ4
Sep 10, 2007 07:31 AM
transamice
Sep 7, 2006 04:06 PM
ILostMyKeys
Jan 15, 2005 01:19 PM
lvega
Jul 16, 2003 03:20 PM
