Fuel pressure question
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I have a HSR with the holley adjustable regulator. When my car is idling I have a constant 48 or so PSI when I rev it slightly it drops and spikes back up. After I shut the key off it will drop to 40ish within a few minutes. I know it should hold pressure with the key off. Could all this be related to the crap Holley regulator?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Fuel pressure question
The throttle blip response is correct as well, vac will fall and spike and fall.
-- Joe
Car: 85 Z28
