Adjustable fuel pressure regulator question
Old May 7, 2005 | 03:25 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have an afpr on the T/A and was wondering, will turning the screw in increase or descrease the fuel pressure? It looks to be in about all the way now.
Now I now the correct and long term answer is to get a pressure gauge. But I don't have one and I am looking for a short term answer.
Here is a pic of my regulator.
Attached Thumbnails Adjustable fuel pressure regulator question-im000563.jpg
Old May 7, 2005 | 03:30 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
tightening it should increase pressure, loosening it shuld decrease it, i believe. way i figure it is that there is a spring inside right? well if the thing is tight it will cause there to be more resistance resulting in more pressure.
Old May 7, 2005 | 06:25 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
That looks like the TPIS regulator I used to run when my car was TPI. If you have it cranked all the way in, that gives you max pressure. You should not be running like that! Having more than 1/2 of the adjuster bolt length sticking out gave me 46 psi WOT (higher than the stock 43.5 psi). If your fuel pump is any good, where you have the regulator should give you over 50 psi! You really need to check on that.
Old May 7, 2005 | 07:12 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Less than one turn from where the bolt contacts the spring on my Holley.
Old May 9, 2005 | 07:47 PM
azvolfan's Avatar
Wow! That's pretty shiney!
Old May 9, 2005 | 08:49 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you have a AFPR it requires a fuel pressure gage for the best results. I have mine mounted just under the STB.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
