Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Miniram testing
Old Aug 9, 2020 | 07:38 AM
Bill Chase's Avatar
Miniram testing
just a thought, but given the close proximity of the throttle body to the 4 front cylinder ports in this intake... has anybody here ever done any testing with throttle body spacers to push the throttle blades further away from the ports, and even allow a gentle radius to be ground into the plenum entry point?
I was reading some old blog info Vizard posted, and watching a couple of his vids where he claims over 25hp increases with the hsr by adding a plenum to base spacer. it allowed him to contour the front 4 port runners in a way that it equalized afr numbers at low throttle, idle, and at high rpm.
it was Vizards hsr testing that made me think of this, basically a little more plenum volume, and a gentler radius to the front 4 ports vs the abrupt bend it has to make in stock form.
robg91z
Aftermarket Product Review
Aug 21, 2012 04:25 PM
Viprklr
Jan 13, 2008 10:32 PM
V8 Slayer
Mar 16, 2005 07:41 PM
CrazyHawaiian
Jun 10, 2003 11:09 AM
HI92Z28
Jan 8, 2003 06:21 PM
