Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Pro Flo XT because HSR is out of stock
Old Mar 11, 2021 | 10:12 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I've been waiting for a HSR since October. Every time it is supposed to be in stock they push it back 2 weeks or a month.
The latest date is March 15th and if it is not back in stock I am going to order the Edelbrock Pro Flo XT.
For a very mild 383 would I be giving any performance up by going with the Pro Flo XT over the HSR?
Old Mar 20, 2021 | 01:02 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Pro Flo XT because HSR is out of stock
Pro Flo XT on its way..
Old Mar 20, 2021 | 08:17 AM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Let us know how it goes. I thought about going that direction.
Old Mar 20, 2021 | 09:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I think they would be pretty close. Have to see how big the ports are and if they can be matched to the heads
Old Mar 20, 2021 | 11:47 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have done countless hours of research over the last couple weeks. Many people say the ports are small and not much metal can be removed. Edelbrock lists the equivalent of the 1205 intake gasket as the recommended gasket. They also state the runners are tapered. I've learned that flow isn't the end all of numbers to achieve with engine parts. A few years ago my friends brother who owns a speed shop and has a flow bench, ported small block ford AFR 205cc heads. He ended up adding epoxy to the intake ports to create a very high velocity. In the end the heads measured out smaller than 205cc but flowed more than stock.
I don't think I am going to run a LS style throttle body, but I might. If I stick with the TPI style of throttle body, mostly for throttle cable and TV cable, I will make a adapter like this one: https://www.corvetteforum.com/forums...ttle-body.html
Old Mar 20, 2021 | 08:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
There was a thread here on the pro flo and porting it. I am pretty sure you can get 1205 on it, and thats plenty for good hp
Old Mar 22, 2021 | 09:56 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
It's getting closer!! Should be delivered in the next day or 2!
I don't know if I will end up doing any porting. The engine is only designed to make 400 +/- hp by 5500 ish RPMs.
I will see how it lines up with the AFR as cast 195cc heads.
Old Mar 22, 2021 | 12:16 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I just sold my miniram on ebay. I understand TPIS is back ordered on these too. I guess not everyone is going LSx.
I'm going backwards lol, I'm putting together a dual plane with a holley sniper and V belts for my current build.
-- Joe
Old Mar 22, 2021 | 12:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
https://www.thirdgen.org/forums/alte...-pro-flow.html
just a few posts down from yours
basically seems to be small at 1.99x1.49 out the box, good for stock heads
can be opened to 1205 which is about afr195 size
Old Mar 23, 2021 | 12:31 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
It's here! 28 days early from Amazon first told me, lol. I knew it would be here quicker when last Friday it showed shipped and arrived in Canada.
THE BEST PART is I used amazon.ca since I am in Canada. The price was $503 CAD with free prime delivery. I think they must have screwed up the USD/CAD pricing.
The ports are small, but not much different that the AFR as cast 195 heads. The width is pretty much the same and just a tiny bit shorter. I wouldn't do more than a light gasket match, and for my needs I could probably run as is.
Old Mar 23, 2021 | 01:59 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was looking at those Enforcer heads from AFR. Same casting as liberty and other chinese heads. I hear the AFR springs and valves are better though.
Can you snap a few pictures of what it looks like inside the runner? Curious how far they can be ported.
-- Joe
Old Mar 23, 2021 | 02:06 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Mocking up LT1 fuel rails. I am too cheap to buy fuel rails. I got these for free. I would just need to weld shut the front crossover and then drill/tap or weld threaded bungs into the ends. I can even use the fuel pressure regulator as long as its the right fuel pressure. I will have to look that up.
Old Mar 23, 2021 | 02:12 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
-- Joe
Pics of the intake or head runner?
Here is the heads starting at post #24 https://www.thirdgen.org/forums/memb...ml#post6403622
Old Mar 23, 2021 | 06:32 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
LT1 fuel rails modified and mocked up with old injectors.
Old Mar 23, 2021 | 09:48 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Old Mar 24, 2021 | 10:27 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
When I used modified LT1 rails I was concerned about tapping them, so I welded the mail ends on. The casting is just really thin, although I was probably just being paranoid.
Looking good!
Looked at the link you provided for the enforcer heads. It does look like they can be ported quite a bit, and the guide area re-worked. Probably a good deal for the money. I might try a set eventually.
-- Joe
Old Mar 24, 2021 | 10:56 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Looking good!
-- Joe
I picked up a couple more fittings but still need 1 more 90* swivel which will be in on Friday. Once I get it together I will pressure test it. If the threaded fittings leak I will weld them in.
Old Mar 25, 2021 | 10:22 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm sure they will be fine. I just got nervous for no reason.
I imagine you did the 9/16 or 14mm oring right?
-- Joe
Old Mar 27, 2021 | 11:19 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
-- Joe
The fittings into the fuel rail were 3/8" NPT
Old Mar 28, 2021 | 03:45 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Fuel crossover done and pressure tested.
Old Mar 29, 2021 | 07:11 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
So how are you bolting the rails down to manifold?
Old Mar 29, 2021 | 07:33 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I made 4 strips of metal with a bend on the top end. They sit against the intake fuel rail mounting pad, then the bend goes along with the factory shape of the LT1 fuel rails. They are secured to the intake with 2 screws each and then a bolt through the existing hole in the fuel rail. I will get some pictures later.
Old Mar 29, 2021 | 08:36 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Old Jun 15, 2021 | 10:46 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
This project is still moving along, even though the HSR is now back in stock 8 months later. lol.
Old Jun 15, 2021 | 01:10 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Got to work on the TPI throttle body adapter. Ideas borrowed directly from Dave_85 on corvetteforum. https://www.corvetteforum.com/forums...ttle-body.html
Looking at the pictures I stuck the TB gasket on backwards.
Old Jun 22, 2021 | 01:01 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
The adapter plate is done.
Old Jun 23, 2021 | 10:34 AM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Why not just go with an ls1 throttle body like the manifold was made for? I'm no expert but I would assume the tpi throttle body on that intake would be a big bottleneck
Old Jun 23, 2021 | 11:06 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
You have to use edelbrock's $500 throttle body that doesn't have a spot for a TV cable. Or a LS1 throttle body and a adapter plate, also the throttle body does not have a spot for a TV cable.
Old Jun 23, 2021 | 11:44 AM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Wow they make it difficult. Any reason you chose just the manifold over doing the entire pro flo xt self tuning kit? I think they go for around $1800 but that includes throttle body, fuel rails, injectors, harness, computer
Old Jun 23, 2021 | 11:58 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Budget, TV cable and pro flo xt self tuning kit doesn't control torque converter lock up.
Old Jul 21, 2021 | 01:03 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Here is the TPI throttle body and adapter on the engine in the car. Close to first start up!
Old Jul 21, 2021 | 02:27 PM
ULTM8Z's Avatar
dying for you to get that beast fired up! Basing some of my 383 decisions on your results... lol...
So don't just sit here posting, finish that thing!
Old Jul 21, 2021 | 09:24 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Me too! I only get a hour or so every other day to work on it. I hope to have it going Saturday by the latest.
Old Jul 24, 2021 | 06:27 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
It's alive.
Old Sep 30, 2021 | 08:54 AM
92Z's Avatar
92Z
How does it run? Whats the powerband and HP potential of this intake?
Old Oct 3, 2021 | 10:30 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
It runs great. Still need a new converter. Powerband is 1500-6000. I would think I am making close to 400hp. With a bigger cam 450hp would probably be easy.
Old Oct 3, 2021 | 05:03 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Looks great! How did the clearance to the hood turn out... looks like everything fits well
Old Oct 3, 2021 | 07:05 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Even with the under hood insulator I had a bit more than 1/2" of clearance.
wruiz
Mar 16, 2016 07:54 AM
rgauder
Oct 25, 2005 11:26 PM
mrr23
Aug 17, 2003 10:50 AM
