Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stealth Ram T Stat Housing Optons?
Old Jul 15, 2021 | 07:46 PM
Shinobi'sZ's Avatar
Options that is lol. Stealth Ram is installed and went together smooth except TPI T Stat housing is too tall. The Rad hose is 1 1/4 and the other T Stat housings I have tried are 1 1/2.....so the Rad hose doesn't fit. Anybody have a part number for a T Stat that works with a Stealth Ram that has a 1 1/4 hose size?
Old Jul 15, 2021 | 08:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stealth Ram T Stat Housing Optons?
A tbi housing should work
Old Jul 15, 2021 | 08:17 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...hermostat.html
Old Jul 15, 2021 | 08:57 PM
Shinobi'sZ's Avatar
Thanks I saw that post when I did a search but didn't see a confirmation on whether it worked or not? The conversation transitioned into one about hood clearance. Is it the RS for the 305 (5.0) that works on a 350 (5.7)?
Old Jul 15, 2021 | 09:15 PM
Engine: Lb9
Transmission: M20
Yes the t stat for 88-92 tbi f body rs and upper radiator hose should be correct to fit the hsr.
Old Jul 15, 2021 | 11:18 PM
Shinobi'sZ's Avatar
Thanks!
JP86SS
May 14, 2005 06:26 PM
Tibo
Jun 26, 2004 06:53 PM
