Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
fitec
Old Apr 10, 2024 | 04:55 PM
senior bear's Avatar
fitec
HI all
has anybody on hear tried a fitec 3004 tbi system i have one to start with not much luck .fitec put it down to low fule pressure .so another load of cash another hi pressure fule pump with fitec writen on it tank out tank in axel up down around around .nearly ready to fire it agai9n .im not convinced .anybody
Old Apr 11, 2024 | 03:07 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: fitec
I am not quite sure what you are asking, if English is you second language you might want to see if google translate can help.
If I am reading right you think you have low fuel pressure even with a new pump?
What symptoms are causing you to think it is low pressure?
What was the fuel pressure with the old pump vs the new when you measured it?
What size supply and return line are you running?
Are you running an inline filer?
Internal or external pump?
Old Apr 12, 2024 | 02:11 PM
Re: fitec
sorry did sumone wake up professor perfect
Old Apr 12, 2024 | 02:17 PM
Re: fitec
fuell pressure 60-80 psi
inline filter new
fi tec new engine new
starts wont pull a skin from a rice puding
wont rev
160 psi cmpression
timing 12 degree
now have fi tec in tank pump .yet to start .with this pump
runns fine with a 750 cfm holly
Old Apr 12, 2024 | 03:05 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: fitec
Professor perfect here, sorry for the delay. Watch these videos:
Then watch this four part series:
Old Apr 14, 2024 | 08:43 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: fitec
I bought a "bargain" used 3003 throttle body (which includes the throttle body, ECU, 4 injectors, and all the sensors and harness, but no interface or fuel pump), so I've been trying to learn more about them.
I've read up on them a little bit HERE but it's sort of hard to get a handle on. A friend of mine has one on his Charger and likes it now, but had an early ECU failure, and found their tech support to be shaky at best. The original external pumps (that look like a stainless steel coffee can, called the Fuel Command Center) seem to have a bad reputation. The new design external pump (Go Fuel) appears to be a better unit, but I think in-tank is still the best option. I hope you'll let us know if it helps.
Some folks put these on and have no issues, while others struggle to a peak of frustration and finally ditch them (that is supposedly the story with mine).
Was your vehicle running OK before you made the switch to EFI?
RKeats
Jul 20, 2019 08:53 AM
DirtySpleen
Jul 18, 2014 10:04 AM
combatdoc
Apr 7, 2013 10:58 AM
1988350bia
Oct 15, 2008 01:01 PM
SaintedCorrupt
Carburetors
Nov 5, 2005 11:58 AM
