Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stealth Ram Throttle Body Question
Old Nov 8, 2024 | 09:01 AM
bru b's Avatar
Have a 90 TPI set up in a 83 Monte SS. Has been on the car for 20 + years.
Installing a Stealth Ram on a new L31.
While mocking up the fuel rails and throttle body, running into an issue with the cable guide and the rail / 90 fitting. The sweep of the guide contacts the fitting and rail plus the cable stay also is in contact.
I've searched and can't really find an answer. Cut off the offending piece, bend the guide, or 85-88 throttle body?
Old Nov 8, 2024 | 09:09 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stealth Ram Throttle Body Question
You can cut the arm, use a 85-88 tb, or see if you can find a helix style spacer . Most spacers I think are nla.
Old Nov 8, 2024 | 09:12 AM
bru b's Avatar
Cutting the arm seems to be the easiest solution.
Have looked with no success for a spacer.
Thanks for the reply
Old Nov 8, 2024 | 09:28 AM
Engine: Lb9
Transmission: M20
Looks like a few places online might have air raid 200-522 but cutting would work.
Old Nov 8, 2024 | 09:29 AM
Engine: Lb9
Transmission: M20
Just found this
https://www.ebay.com/itm/25522514022...mis&media=COPY
Old Nov 8, 2024 | 10:17 AM
bru b's Avatar
Thanks for the link, will give it a try.
STEALTHWRAITH
Apr 13, 2025 07:27 PM
codemonkey
Jun 25, 2012 09:14 AM
irocz43
Nov 30, 2003 02:38 PM
iceman02
Jul 28, 2003 08:10 AM
JMatlock88
Oct 16, 2002 11:15 PM
