Anything Special Before I Clay Bar My Car??
Old Apr 27, 2002 | 12:53 AM
2ponchos's Avatar
just wondering getting ready to do the spring clean up and wana try the clay bar out.. my car was painted bout this time last year.. its say all winter still waiting to start it but getting ready to clean when it does start!! (new motor).. so i wana try the clay bar and i use wizards polish on it.. no money to try zaino yet.. but i will.. so let me know thanks!!
Attached Thumbnails Anything Special Before I Clay Bar My Car??-firebird_0004.jpg
Old Apr 27, 2002 | 01:16 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just go over the car carefully and keep the clay area wet at all times. The clay bar removes all impurities and will remove paint if you rub the same area too much. also, throw the clay away if you drop it. It will scratch the car. As for the polish, keep using Wizards. You'll probably like it just as much as Zaino!
Old Apr 27, 2002 | 01:30 AM
2ponchos's Avatar
what should i use to lube the clay bar? water or liquid soap?? circle motion or back and forth?? yes i love wizards and i think i am going to use thier clay bar also..
Old Apr 27, 2002 | 04:09 AM
Jza's Avatar
Jza
The clay bar should come with it's own lube in a spray bottle.. If not, then use a solution of water and car soap, never water alone.
Back and forth motion. This keeps potential swirl marks to a minimum. (If you make fine scratches they'll be in a straight line instead of little circles, therefore will be less noticable).
Old Apr 27, 2002 | 04:27 AM
2ponchos's Avatar
thanks for the help!!!!
Old Apr 27, 2002 | 07:33 AM
FiReBReTHa's Avatar
yes you may kick my butt...
but what does the clay bar do?
bluntly. thanx.
Old Apr 27, 2002 | 09:13 AM
WaynesRS's Avatar
I only was able to clay bar my trunk , then I dropped it ! I was so pissed !
I know he already say it , but I'll say it again . Becarefull not to drop the clay !
Old Apr 27, 2002 | 09:18 AM
scottmoyer's Avatar
The clay bar draws out any impurities in the paint. This includes fallout, dirt, sap and rail dust. If you lightly run your hand down a section of paint, you might feel some minor bumps. The clay bar draws them up into the bar and off the paint, leaving a perfectly smooth finish. Even without wax.
Why don't you want to use just water alone? I did my wifes entire car this way and it turned out fine. Is there a reason for it or is it just a recommendation?
Old Apr 27, 2002 | 09:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Exactly, mine slid off the hood, but it was salvageable.
The surface must be wet as possible, mine came with Mothers Polish spray. Just rub the clay bar back and forth lightly and you'll hear the contaminants being picked up like a gritty sound, once that sound goes away move on to the next spot.
Old Apr 28, 2002 | 01:34 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
ewwwwwwwh! That makes me wince at just the thought of it!
Old Apr 28, 2002 | 02:17 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm pretty sure you have to stretch it a lot too so you don't drag the stuff you pulled out all over the paint.
Old Apr 28, 2002 | 10:18 AM
Car: 99 Formula
Axle/Gears: 342
You're supposed to roll it into a ball and flatten it out after doing a few spots, or I just did it when it got dirty looking.
Old Apr 28, 2002 | 11:25 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Do you have to dawn your car before using it?
Old Apr 28, 2002 | 11:53 AM
scottmoyer's Avatar
You don't have to, but I have heard it is recommended. The Dawn will remove the wax. If you don't wash it with Dawn first, then the claybar will remove the wax and fill up sooner.
Old Apr 28, 2002 | 04:19 PM
Jza's Avatar
Jza
It's even worse when you're experiencing it the first time. Feels and sounds like rubbing two clay pots together. You start to wonder if it's really a good idea until it finally smooths out and the paint is so smooth. Then you're hooked.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mizz0313
Aug 12, 2015 06:45 AM
NBrehm
Aug 5, 2015 07:57 PM
