window-mount 3rd brake light
Old May 25, 2002 | 02:54 AM
logikal6785's Avatar
i have an '89 firebird gta. it already has a 3rd brake light but it's mounted with the aerowing spoiler which i am going to get rid of.
i want to get a 91-92 high rise spoiler and put a 3rd brake light mounted to the [ Outisde ] top of the rear window so i keep the lines clean. has anyone done this before / is there any forseeable obstacle to doing this? would it be possible to power it off the rear defroster ?
thx
Old May 25, 2002 | 07:05 AM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
I dunno, but won't you have to drill mounting holes in the glass?
Old May 25, 2002 | 07:19 PM
EvilCartman's Avatar
Car: '82 Z28
Could get the hatch off an 86 with the 3rd brake light mounted on it. Or I think in 87 they had it inside the glass but still mounted up top, not sure though.
Old May 26, 2002 | 02:13 AM
Sauron91's Avatar
91-92 birds had one mounted on the inside of the glass..such is the case with my 91 GTA and 92 T/A..
Old May 26, 2002 | 10:40 AM
Tonyrodz's Avatar
Transmission: auto
You don't need to drill into the glass(like the 86's) the 91-92 inside brake lights were put on w/double sided tape.
I'm going to do the same thing to my 86-i planned on running the wires behind the inner panel(where the 6x9's are)and into the wiring for the brake lights. Shouldn't be too hard at all.
Old May 26, 2002 | 05:26 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Here's an interesting technical tidbit:
On the '86 cars with the external brake light, the light gets its power from two contacts mounted next to the latch. the wiring is actually applied on to the inside of the glass like the defroster grids. the power then goes through the tail light mounting screws in to the light itself.
The defroster grids' power actually comes from a couple of contacts on the hatch struts.
If it was me, I'd go with the '91-'92 internal brake light, because it doesn't require replacement of the rear window, extra contacts and the like. If you really want that external light, make sure you get all contacts and stuff from the latch area for stock operation. I suppose you could just stick the tail light on the glass, and drill a hole in the weather stripping to run wires through.
*all technical data pertaining to 1986 brake lights is based solely on me walking outside and looking at my car. please do not accept it as the truth, the whole truth, and nothing but the truth*
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
