Check out my hidden shiftlight!
Old May 26, 2002 | 09:33 PM
IROC57TPI's Avatar
I hid it behind the stock sig lighter. I like to keep things "stealth"
Comments or questions welcomed
Old May 26, 2002 | 10:11 PM
89transam's Avatar
Sweet.
Thats pretty slick.
:hail:
Old May 26, 2002 | 10:16 PM
88txiroc's Avatar
Me like it!! But what if you are a smoker? LOL Looks good and very steath. Maybe a tech article?
Old May 26, 2002 | 10:35 PM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
There is a place for it, the one on the right of the SES light it is used on 89+ T5.
Old May 27, 2002 | 12:02 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Cool idea, nice work man.
Old May 27, 2002 | 07:50 AM
82resto's Avatar
Excellent. Way to add function without overdoing it. Very good looking.
Jon
Old May 27, 2002 | 08:36 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
ME TOO!
I found that was an excellent place also
Old May 27, 2002 | 08:55 AM
IROC57TPI's Avatar
Re: ME TOO!
You !@#$% I thought I was the innovator
Good job on the install, but can you hide it with the lighter ****? Even when it's set inside the tube a little you can see it in sunny daylight.
Off the topic... I love the white face gauges. Hwere did u get them?
Old May 27, 2002 | 09:27 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
:rockon: Good work man! Next you should put some NOS in the ash tray!
Old May 27, 2002 | 11:33 AM
IROC57TPI's Avatar
I got my TCC lockup switch in the ashtray, thats stealth too
As for NOS, I can hide the comlete system including the electronics like no other.. :hail:
I will post pics as soon as I get a kit installed.
BTW- In case some of you are wondering..... that a Harlan Engineering shiftlite that is completely programmable without those stupid module the MSD and others use. If you want one heres a link Click this for Harlan Engineering
Old May 27, 2002 | 12:08 PM
Kandied91z's Avatar
mike.......you never looked inside my car did you? tsk, tsk...........i was wondering if harlans lights would work with our cars, i had asked him; but never got a reply.
check out macewen motorsports for the overlays, they are relatively cheap and look really sharp. email me and let me know what you did with harlans light, i just removed the msd one i had in there because of problems.
Old May 27, 2002 | 12:49 PM
BumpaD82's Avatar
Re: Re: ME TOO!
The gauges are Macewn, and they ROCK!
http://members.aol.com/rmacewen1/
Ang yes I have a lighter **** cover for it (black), but it's NEVER on (sorry no pic of it) since I'm always wrapping it up, right now mine is set a 5500 RPM... a few people over at UFBA.org have seen and are going to copy this idea as well... it's to good of a place not to share with other
Old May 27, 2002 | 01:19 PM
TransAm87's Avatar
nice
I like that, i love seeing other peples mods
Aj
Old May 27, 2002 | 03:15 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
That looks tight. Oh, your service engine soon light is on . How much did those white face gauges cost BumpaD82?
Old May 27, 2002 | 03:42 PM
IROC57TPI's Avatar
The service engine light is on cause I cycled the key one time to get the shift lite to go thru its test cycle. I wouldn't be caught dead driving around with the SES light on :nono:
Jeff,
The lite hooks up with 3 wires. Switched + (red) ign. trigger (green) and ground (black)
Its fairly simple to program and comes with idiot proof instructions.
All I did was take the lighter out, open up the hole a little bit with a file, and glue it in the hole. I used the defrost switch for power and ground and hooked up the green wire to the MSD 6A's white trigger wire.
By far the best shiftlite out there. For $55 i think its a great investment. You can also hook up a relay to it and have an RPM activated module that will turn on NOS, etc.
Mike
Old May 27, 2002 | 04:00 PM
Timmys88Z's Avatar
you bastard.... I've had that idea in my head for a looong time. Cool though.
Old May 27, 2002 | 04:09 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Snazzy
Looks good. Stealth eh
Old May 27, 2002 | 05:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
Nice job. I didnt think many thirdgen owners had the harlem light. I just finished installing mine along with 2 other gauges in a panel inside my cowl hood. it looks great. i wil have a ton of pics of my car when its done.
Old May 27, 2002 | 06:14 PM
Bill Krumel's Avatar
IROC57TPI
You will spend $75.00 for MacEwens guages. I suggest doing the DIY white face guages. PennylessZ28 has a great site with instructions on how to do it. You can even download the templates off his site. I think they look just as good as MacEwen at a fraction of the cost. You can even add your own customizing touch like I did with the RS image on the speedo and the chevrolet on the tach...
On the shifter light can you install one of these on a automatic? I guess you could and then go from 1 to 2 to D to OD would that work?
Old May 27, 2002 | 11:27 PM
IROC57TPI's Avatar
Originally posted by Bill Krumel
IROC57TPI
I have mine on my automatic car. If I leave it in OD it shifts automatically around 4500RPM, but I like to hold it a little higher on occasion.
BTW- Got a link to the WFG site?
Old May 27, 2002 | 11:43 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
IROC57TPI
How are you going to put the needles in without messing up the calibration???
Old May 27, 2002 | 11:47 PM
How hard is it to install one of those shift lights in the cigarette lighter? Where does it hook into? I have an automatic so would the light go on every time my car shifts? That could get annoying when your not racing....
IROC57TPI
Here is the link to the DIY white face gauges
http://www.mikekey.net/fbody/whitegauges/index.html
I am almost done redoing mine. Instead of CD labels this time I went to Kinkos and had my guages laminated to make them shiny and more durable. Then I am using 3M double sided carpet tape to attach them. Its very fun trying to get the boxes for the mileage and trip perfectly straight. I figured out the best way for me was getting those box knife blades and cutting them to size with a dremel and then just hitting them lightly with a hammer... As for the circles I used a punch. My dad had a whole set of different sizes.... I should have pics soon..
If you have any questions feel free to contact me.
Old May 28, 2002 | 11:27 AM
IROC57TPI's Avatar
The shift lite is so easy to install in the cig lighter hole.... heres a few tips:
1) Remove cig lighter/defrost switch panel with T-15 bit.
2) Unscrew lighter retainer ring from the rear of panel.
3) You will now have removed the lighter assembly from the panel leaving a hole. Open the hole slightly with a file until the shiftlite fits snug in the hole.
4) Glue it in place.
5) Your switched power and ground come fromt he stock defrost switch. On the left side of the switch there are two terminals. The black one is ground and the other is switched power. Tap into these to power up the lite.
6) Test your progress. Turn ign. to "on" position. Lite should blink once to confirm power on.
7) Run a single tach signal wire from the white wire on the coil that is closest to the front of the car. There are two, make sure you get the one closest to the front of the car.
8) run tach signal wire inside passenger compartment to the back of shiftlite "green" wire.
9) Put it back together and follow programming sequence as per instructions.
Simple really
Old May 28, 2002 | 11:29 AM
IROC57TPI's Avatar
Bill,
Let me know how accurate the gauges are afterwards. The whole taking the needles off thing kind of intimidates me. I would like to make sure my gauges work as they did from the factory.
Thanks for the tip...
Mike
skeltor
Feb 2, 2016 10:37 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
86IROC112
Sep 11, 2015 04:04 PM
Nick McCardle
Sep 10, 2015 08:36 PM
