Damn swirl marks!!!!
Old Jun 14, 2002 | 11:37 AM
Knight350's Avatar
Well guys... I'm almost finished sanding down the tpi plennum, I wetsanded with 1500 and polished at low speed with mothers mag restorer, and it left alot,I mean alot of faded swirl marks on the finish. Anyone have any idea's? Trust me, at this point anything is worth a try, it hurts to have to resand that flippin thing...
Thanks in advance..
Fredel
Old Jun 14, 2002 | 12:03 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Back to 400... spend a lot of time on 400- its the last grit that actually "removes" the scratches. After you do 400, buff with the polish. It should look dull and show any scratches you miss. If you buff and see scratches, sand them with 400 and test buff again. Once it is flawless (or as close to flawless as you're willing to settle for), go to 600, 800, 1000, 1500, 1500 wet, and buff again. Should be nice and shiney by then. Good luck
Old Jun 14, 2002 | 01:14 PM
Knight350's Avatar
(I had bad feeling about that...)
Thanks alot MetalliCamaroRS, now that you mention the other grades of sandpaper I truly realize how much I cut corners...
Thanks again for your help, I going back to 400 tonight...
Take care
Fredel
Old Jun 14, 2002 | 02:52 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Yeah, definitely do not cut corners on 400. Good luck, post pics when you're done!
Mark_ZZ3
May 24, 2018 01:02 PM
apie2546
Oct 16, 2016 02:24 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gord327
Oct 3, 2015 01:25 PM
