Gauge Layout Opinions
Car: 91 Z28 Convertible
Engine: 305TPI
Sorry I dont have exact pictures to post but I was wondering which dash layouts you guys perfer as in ease and general look of the gauges. I am not talking about overlays or anything like that. Like Pre 90 clusters, 90-92 clusters or 4th gen clusters. These pics are with the overalys but I am talking about the configuration more.
4th gen reverse EL
<img src="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=698013">
Pre-90 White Face
<img src="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=641057">
90-92 LED Conversion Dash
<img src="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=655719">
90-92 White Face
<img src="https://www.thirdgen.org/rides/rideimages/Mvc-005f.jpg">
4th gen reverse EL
Pre-90 White Face
90-92 White Face
Car: 1992 RS
Engine: 406 Stealth Ram
Duh, the first one!!!
I'm actually trying to investigate what kind of signals those gauges work off of. If they work off the same tach signals and VSS signals that 3rd gens use, then it could be an EZ swap, but we'll have to wait and see. I am pretty sure the tach signal is gonna be different since 4th gens dont use a distributor, but I bet there is a way to convert the signal with some simple electronics. The VSS signal I'm assuming should be the same, since the 700-R4 and 4L60-E are fairly closely related.
I just noticed you're in Owings Mills. Isn't that were Motorweek (the TV show on PBS) is filmed? Must be nice to have all those nice roads to drive on, punk!
I'm actually trying to investigate what kind of signals those gauges work off of. If they work off the same tach signals and VSS signals that 3rd gens use, then it could be an EZ swap, but we'll have to wait and see. I am pretty sure the tach signal is gonna be different since 4th gens dont use a distributor, but I bet there is a way to convert the signal with some simple electronics. The VSS signal I'm assuming should be the same, since the 700-R4 and 4L60-E are fairly closely related.I just noticed you're in Owings Mills. Isn't that were Motorweek (the TV show on PBS) is filmed? Must be nice to have all those nice roads to drive on, punk!
Engine: 305TPI
I'm wanting something like the whites (the big round ones) but the bright LED's with them. Does someone make these or is it a DIY? Does the fact I have an 88 with the 150 speedo complicate things and limit my choices?
Car: 1992 RS
I've semi-confirmed that the 4th gen LT1 tachs hook up with by the same method (Green wire from the distributor, well, opti-spark). So that means that the tach most likely would work without a problem in out cars. I'll try to get my hands on an LT1 gauge cluster to see if this stuff actually works...
Car: 1992 RS
I called a GM dealer, and it looks like the part numbers fo the VSS on a 92 Camaro and a 94 Camaro are very different, but that still doesnt mean much. I'm going to try to get my hands on an LT1 cluster so I can test them out.
