Help ME QUICK, NEED AND ANSWER TONIGHT!!!
Old Jul 1, 2002 | 08:09 PM
no_car_yet's Avatar
I locked the keys of my car in the ignitiion, with the doors locked and t-bars on! the driver door didn't close all the way, can you help, it has power windows... PLEASE HELP ME HERE!!!!!
Old Jul 1, 2002 | 08:10 PM
MG86TA's Avatar
Call AAA
Old Jul 1, 2002 | 08:11 PM
BadBird84's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
I hate to say it, but buddy, you are what we here at ThirdGen.org would call screwed, call a locksmith
Old Jul 1, 2002 | 08:12 PM
KlayBuRn's Avatar
Coat Hangers are your friend, or call your local friendly police department, they got my keys out in about 3 minutes
Makes me feel safe...
Old Jul 1, 2002 | 08:15 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Most of the time, you're crap out of luck. Cause some don't like to give out secrets on these boards, never know if the person would use it for negative reasons. I'd say call a tow truck place.
Old Jul 1, 2002 | 08:20 PM
no_car_yet's Avatar
the BABB got it for me for 46 bucks!!!canadian of course, about 30 bucks!, still alot!
Old Jul 1, 2002 | 08:27 PM
Car: 99 Formula
Axle/Gears: 342
When I had my '85 Stang, I locked the keys in the car, no spare. The tow truck guy came out and tried for like 10 mins, then finally smash, he used to much pressure and broke the glass. OMG was I pissed, but they installed a new window for me.
Old Jul 1, 2002 | 08:38 PM
JAY4SPEED's Avatar
I'd see if I could find a wire or something long enough to put between the glass of the door thats not closed all the way and try to hit the hatch switch on the center console. It's easier than trying to hit the window switches for the windows or doors.
Old Jul 2, 2002 | 01:08 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Yeah if you have a power hatch try and pry a window down and stick somethin in a pop the hatch. If not, you're screwed.
Old Jul 2, 2002 | 01:14 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
If ya had a slim jim I can get into your car in litterally about 5 seconds. hehe Gee ya think I locked the keys in my car a few to many times.
Kat
Old Jul 2, 2002 | 01:20 AM
MG86TA's Avatar
Slim jim wont work, Coat Hanger wont work because the door locks work sideways cuz of power locks, and a wire cant hook it either.. He also has a firebird, so the trunk release is in the middle by the guages and its a push button.. i would say try and whack the power lock button on the side.. bend the coat hanger so you can press it
Old Jul 2, 2002 | 01:23 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Ummm right and what did I use to break into my own car. It doesnt matter if you have power locks or not. The slim jim is used to open up the latch while the door is locked. Dont believe me. Get me a slim jim and I"ll show ya on your car
Kat
Old Jul 2, 2002 | 03:31 AM
zer0321's Avatar
If you don't mind killing the exterior window stripping and replacing it, which probably should be done anyways, judging by the age of our cars, proficient used of a long flathead screwdriver will get the door open...
Old Jul 2, 2002 | 06:45 AM
89 Iroc's Avatar
Ok this is what you do. Get a coat hanger and totally straighten it out. At the end that used to to be the hook part make a 90* degree bend 2 inches from the end. So now you have what looks like an L. Ok now stick that into the window with the L part inside the car. Then unscrew your antenna and slide that into the window and use it to push the hanger into the door lock switch. I've done this many times on my car and it never takes more than a minute.
Old Jul 2, 2002 | 07:22 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
slim jims work on horizontal locks you just pull back instead of up. actually there are slim jim and wedge tools made specifically to crack open thrid gen camaros...isnt that nice
Old Jul 2, 2002 | 07:36 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
<font color=red><h1>YOUR NOT SCREWED!! read this</h1></font>
I have dont this twice and that two times to many. Well its 7:45AM here in Texas I might be a little to late but I can break into any third gen in less then 45 seconds. Here is how...
>Go to home depot and bring two bucks.
>Get a square steel rod that is about 5 feet long and about a quarter inch thick. (Make sure to get the thick one other wise the small one will just flex and thats not good)
>Take it to the card and just to look at it put one end where the lock is and the other where the far rear corner or the driver window. Just place it at the side of the door and window just to see where you will have to make a slight bend in the rod.
>after you make the bend stick the rod in the far right corner of the window with the bend you made you can angle it over to the lock.
>here is the easy part, Just push the lock open.
>Last step, Go the a keymaker and get a copy of you door key then stick it in your wallet.
I wish I had a pic of that rod but Im sure you know what a 5 foot rod that is a quarter inch thick looks like. Well if you got in already great! Just lock then in there again to try my idea.
<font color=red>to be continued on how to break into and start a thirdgen in less that a minute and a half!</font>
Just ing I dont know how to do that LOL
Old Jul 2, 2002 | 08:46 AM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
didnt anyone realize that he said that he got into it for $46CAD?????????
Old Jul 2, 2002 | 08:54 AM
Yeah, Guess he will have to change his user name. Man thats cheap!!
Old Jul 2, 2002 | 09:00 AM
Zuckuss88GTA's Avatar
THIS IS ONLY FOR INFORMATIONAL PURPOSES ONLY!!!
While on the internet i came across this site.
http://www.phrack.com/show.php?p=43&a=20
Look for the txt file pn stealing a camaro. It tells you a little more then how to get into one without keys.
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
