Polished plenum and runners on E-bay...
Old Jul 6, 2002 | 06:26 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Check this out, perfect for those of you who are wanting to polish the intake on your cars...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1842028931
Old Jul 6, 2002 | 08:15 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Hell yeah! for 125 too It will go up though. I would bid if I had a TPI setup. I got the old TBI in my ride.
Old Jul 6, 2002 | 11:46 PM
TransAm87's Avatar
I have a polished plenum and the rest of the TPI setup for sale if anyone is interested
Aj
Old Jul 7, 2002 | 12:17 AM
89Formula305's Avatar
heres what ive been doing today...
Old Jul 7, 2002 | 12:19 AM
its not done yet but to give you an idea of what it looks like after 600 grit sand paper, I would have kept going but I 600 was the highest i have right now.
Old Jul 7, 2002 | 12:58 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
So Miracle Whip comes in handy when polishing huh?
Old Jul 7, 2002 | 01:02 AM
Fred91GTA's Avatar
Car: 1991 GTA
Hey, would an '88 Corvette TPI system like that work for a '91 F-Body L98 like in my car? I know that system uses MAF, and has 2 vacuum lines going into the plenum on the pass side, and one on the driver's side, while the SD system in mine has all three vacuum lines going into the plenum on the pass side. Thanks in advance for any help.
Fred
Old Jul 7, 2002 | 01:07 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
The 88 intake will work, you can either do the simple solution by installing a "T" in one of the vaccum lines, or drill and tap another hole in the rear of the 88 plenum (also pretty easy). I ran a plenum from a 1988 GTA on my 91 Camaro for a while, I had just used a "T" in the brake booster line for my A/C vaccum line.
Old Jul 7, 2002 | 02:02 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Here you go
Old Jul 7, 2002 | 02:05 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Yes, I do alot of these...
Old Jul 7, 2002 | 09:10 AM
TransAm87's Avatar
https://www.thirdgen.org/classifieds....tgo?adid=3755
Old Jul 7, 2002 | 11:58 AM
Fred91GTA's Avatar
Car: 1991 GTA
RU-QWIK, Those plenums are beautiful!! Was that done out of hand polishing or did you use a rotary tool?
Fred
Old Jul 7, 2002 | 12:15 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I use tools, doing them by hand would take forever... Some of these guys go that route, but I prefer to spend a total of 45 minutes to complete a plenum
Old Jul 7, 2002 | 01:07 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Another
Old Jul 7, 2002 | 01:32 PM
Hehe.. I can see that Formula doing the wheel stand.
Old Jul 7, 2002 | 02:10 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
ru quick... 45 minutes ... what are you using... I spent about 5 hours on my Superram jsut doing the plenum and lid... I used an electric sander up to 220 grit then the rest bay hand.
Old Jul 7, 2002 | 08:37 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
45 minutes? Please, do tell... I'd love to polish my plenum and runners but I don't want to spend half of my vacation doing it.
Old Jul 7, 2002 | 08:51 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I have a large selection of tools and sandpaper, and experiance. I lost count of how many TPI intakes, wheels, misc. parts, etc. I have polished. I would guess around the neighborhood of 45-55 intakes.....
Old Jul 9, 2002 | 11:34 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Hey RU-QWIK, Why is the grooves on the plenum on the right longer than the ones on the left? Did you fill them in? IF so with what? It looks super clean. BTW, the bid is up to $305 on the polished stuff on ebay with the reserve met. Not too bad but it will go up some more. Great job on the polishing RU! I havenot decided weather I want to polish mine or not but man they do look good!
Old Jul 9, 2002 | 06:28 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
The "grooves" in the top of the plenums are longer on the older ones. I think 85' to 88 got the long grooves, and the 89 - 92 got the shorter ones. The Corvette, I think got the shorter grooves in 88. I do not know exactly what years, but that gives you a ballpark. I have a ton more stuff to put on e-bay that I have polished. I guess I did not realize the demand for polishing work. I have anything from valve covers, to Mustang 5.0 intakes.... Hopefully all this can finance my new bench for buffing.:lala:
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Royal_Z
Sep 30, 2015 08:45 PM
