Rim and Tire size
Rim and Tire size
Whats the biggest rim and tire combo that can go on a 82 Camaro? I want to be able to run 15x10 rims in back with 15x8 upfront is that possible, i could go smalle ron the front like 15x7 but woul dlike 15x8. I would like to run really beefy wide tires in the rear like 295's or 325's, and 225's upfront, is this possible wiht a car like this?
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
i have a friend with a 82 t/a and he's got 15x8s on the front and the back with 235/60/15 all the way around. the front tires rub a little on the plastic wheel wells but its no major problem and no problems on the back. you should be able to get 15x10s on the rear with no problems with atleast a 255 tire. not forsure about a 295 or 325. thats getting really wide. might rub on the inside of the body. would have to do a test fit.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
