Need help removing overspray.
Old Jul 22, 2002 | 10:41 AM
gerry's Avatar
I need to know what I can use to remove overspray from the parking lights. The people at the body shop got some paint over the lights, so any help would be appreciated. Also, to everybody who responded to the orange peel problem I had, thanks a lot. I got the problem solved.
Thanks,
Gerry :rockon:
Old Jul 22, 2002 | 10:47 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get a clay bar.
Old Jul 22, 2002 | 11:43 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Also, if that doesn't work, wetsand it with some finer grit sandpaper...polish 'em while you're at it.
Old Jul 22, 2002 | 03:31 PM
rich88gta's Avatar
Take it back to the body shop and ask em WTF is this!!!!!!! They should have done a better job of prepping thier work.
Most body shops will fix the overspray, no problem.
Old Jul 22, 2002 | 03:33 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Over spray is incuded in macco paint jobs.
Old Jul 22, 2002 | 04:33 PM
castrolSi's Avatar
#000 Steel Wool is an amazing thing to keep on hand. Comes in
handy for just these occasions.
~castrol
Old Jul 22, 2002 | 06:21 PM
19WS6T/A91's Avatar
i would try either steel wool or a razor blade. i had a little bit of overspray on my windows and i just used a razor blade and it came right off.
Old Jul 23, 2002 | 11:48 AM
gerry's Avatar
over spray
Thanks everybody, I'm going to try the clay bar first. then if that doesn't work i'll use the steel wool and/or the wet sanding.
Thanks,
Gerry:rockon:
Old Jul 24, 2002 | 10:08 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I've used WD40 before and it worked wonders.
Old Jul 24, 2002 | 10:19 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Have the same problem. Steel wool (or brillo pads with the soap) work wonders.
Old Jul 24, 2002 | 12:11 PM
gerry's Avatar
overspray
Thanks guy's. I'm going to clean up the mess this coming weekend and keep you all posted.
Thanks,
Gerry:rockon:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
