Another polished TPI on E-bay...
Old Jul 31, 2002 | 07:10 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Just wanted to let anyone looking to make the underside of a TPI hood look outstanding know about this.... I figure it also falls under the TPI and Appearance & Detailing boards....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1847951295
Old Jul 31, 2002 | 07:21 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
just curious... If I were to buy that polished beauty, what else would i need to make it run on my LO3? ecm, wireing harness...?
any info is greatly appreciated
Old Jul 31, 2002 | 07:27 PM
phineas's Avatar
If it's a '91-'92 speed density system, look here: https://www.thirdgen.org/newdesign/tech/tbitotpi.shtml . Otherwise, search the boards quick and you'll see what's necessary to go to the older style TPI. May want to ask the seller what year/model car it's off of. But generally it boils down to the TPI setup (plenum, runners, manifold, TB, fuel rails, injectors), wiring harness, sensors, and ECM. Those are pretty much the major components. There's probably some other things as well, so check out a few people's stories to get all the info. The most time consuming part is probably doing the wiring harness, it can be a big headache trying to route all the wiring and get everything in the right place.
Old Jul 31, 2002 | 07:33 PM
Car: 2001 Camaro SS
Transmission: A4
thanks! I'm researching details as I type...
Old Jul 31, 2002 | 07:37 PM
phineas's Avatar
Oh yeah, forgot a really important one - fuel pump! The TBI pump just won't cut it, since the TPI runs something like 45psi stock (don't quote me on that). I can't remember if you need to replace the fuel lines (I'm mainly thinking the ones in the engine compartment), but you'll figure that out when you look up info on the pump swap. That's also gonna be a PITA, since ya gotta drop the tank...
Kyle
Old Jul 31, 2002 | 07:43 PM
Car: 2001 Camaro SS
Transmission: A4
ya, i just read that in the tech article... thanks anyways
86IROC112
Sep 29, 2015 04:07 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
