clear coat this!
Old Aug 17, 2002 | 10:36 AM
Opha's Avatar
clear coat this!
just wondering...since i know diddley squat about auto paint and stuff. how many layers of clear coat are recomended? and is more better? what is the added effect of using 2 layers as to using 5?
thanks,
Opha
Old Aug 17, 2002 | 12:38 PM
trigger GTA's Avatar
Car: 92 TA vert
the more coats you add the deeper the color and shine. it will also protect better aswell
Old Aug 17, 2002 | 02:05 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i recommend around 2-3 coats. that should be enough
Old Aug 17, 2002 | 02:22 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
If you can afford it stack on a few. BTW does anybody know if macco even uses clear coat?
Old Aug 17, 2002 | 02:32 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I doen't think maco would use a clear coat. Takes to long to paint. I would go with about 5-7 coats, if you could. It would be better for the car. And you would have more to work with as far as buffing goes. You should use 2-3 coats of the base coat.
Old Aug 17, 2002 | 05:23 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
BZZT, WRONG ANSWER. Maaco uses clear coat(at least here it does). If you wanna go cheap, it's mixed into the paint, if not, they do it seperately.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
Stryker412
Sep 7, 2015 09:11 AM
