Ok, now I am undecided, again. Wheel opinions
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ok, here is my car with the WS6 wheels,
And she is with the OZ's,
I am starting to like the OZ's as well as the ZR1's.
I want the ZR1's with the 17x11 rear wheels since I like the wide stance.
So, what do you guys/gals think? Keep the WS6's, OZ's or get the ZR1's?
ps: these are actual pictures, not photoshopped.
thanks,
there are more pics of the OZ's here,
http://www.transamws6.com/pics/oz/
They are full res pics straight from my Digicamera.
The OZ's are wider, makes a 275/40 tire wider and lower profile, since they are 9.5" wide vs 9".
I vote oz, I really like the ws6 wheels as much as the ZR1s (well, zr1s a tiny bit more) but those wheels just look good. Since you are going to paint the car black (I think) I think it would look a lot better than ws6 or zr1 wheels for some reason.
Originally posted by gtabadboy
Where can you get those Centerline Mojave rims? They look great.
Zepher keep with the WS6 rims and have them sent and get them chrome dipped or do what the coolector edition TA's have where the 5 spokes are black and the rim edge is polished. kinda like the GTA black lace rims.
lol oh yeah ur pics just reminded me of a 4th gen i saw the other day. it was a black 4th gen TA dont know the yr but it was around 98-99 yr. and it was black and where on ur car it turns purple it was the same on the 4th gen. i wish i had the digital camera to take a pic but couldnt.
Car: 86 Iroc-Z28
Engine: FB385
Sell the OZ and WS6 wheels and get the black ZR1's, with the polished lip! Go for the 17by 11's in the rear too, that would look bad ***, especially if you were going to paint the car gloss black again! People will always have a different opinion, just do what YOU like. good luck!
Thirdgens look good with wheels that have a dished lip on them. Hence the Formula wheels and GTA wheels are deep set. The firehawk wheels are dished in as well. So I say find something with a lip to it, and your thirdgen will really look good. Its more of a racing look anyway.
Personally I think the OZ wheels look cheap, and if you dont plan on any other wheels than the ones listed, I say stick with the WS6's.
0z's
i vote for WS6's. that way you get some good lookin rims, your not looking for money for ZR1's and you can send me the OZ's for my car
OZ's are the best, and are going on my car in the future!:hail:
P.S: 1 more question....have you decided on a color yet?
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Since were talkin 3rdgen, here, the WS6 if you want to be unigue! Which I know you do
You see a lot of thirdgens now with the ZR1s. They look better on Camaro's anywayz.
the OZ wheels are deifferent, but they seem to flat for me...
You see a lot of thirdgens now with the ZR1s. They look better on Camaro's anywayz.the OZ wheels are deifferent, but they seem to flat for me...
Backspacing etc...
Those FWD rims are not offset properly and you will need to spend extra $$ for them to fit properly.... I don't believe in adapters. I think it hinders the performance the cars were designed for.
It's your money... but I feel it is much better to spend the same if not less for the Mojaves and not have to worry about the backspacing at all.
The money you THOUGHT you saved is spent on the adapters you need to get them to fit!
I think FWD rims on a RWD vehicle look funky. But that is my opinion. I think it is another FAD soon to be changed once more....
Spider7, I will tell you those wheels come in several different sizes and offsets.... so the price varies. Like I said in my other post, check with them at the website and call a distributor in your area to find out. They are worth it.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Re: Backspacing etc...
I just see anywhere for performance to be hindered.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Originally posted by 91z4me
Ronal's firehawk rim above all others. Maybe with a plack powdercoat on the inside of the rim and a polished black lip.
To me, I don't like the "deep dish" part about them. I like the WS6 wheels on thirdgens, but they are too played out on fourth gens.
If were talking 4th gen T/A's, its defiantly Polished Y2K Vette Wheels :hail:
Re: Re: Backspacing etc...
Originally posted by stuart69427
Why do you suppose that? THere are ten lugnuts per wheel, and in Manny's case, thats only on the front! He has the 4th Gen Rear End, so no adapter in the back are needed.
Well I think you should do some reading up on offsets and the reasons behind them....
Yes it does affect the way the car handles.... oversteer is what usually occurs with FWD.... Understeer with deeper rims...
Some websites have quite a bit of information on the subject... the zero offset of the thirdgens are what makes them outperform 4th gens in a lot of ways, and by doing this, you are just making your car oversteer.
It's your car, and do what you will, but the reason they designed and engineered our cars like they are... it is to optimize everything for it's own performance. You will be taking away from it with adapters... ESPECIALLY with the front wheels.
Try this link... maybe it will help you understand more about offset than the Tire Rack or any other seller of rims....
http://www.usacomp.com/Offset.htm
There is more to it than adapters.
Originally posted by 86IROCNJ
Get some ZO6 wheels, that's what i did!
Re: Re: Re: Backspacing etc...
I think you mean you just don't see anywhere the performance would be hindered....
Understeer and oversteer aren't just from the type of wheels you are running.
Oversteer happens on FWD since the front wheels are pulling the car.
Understeer happens on a RWD car since the rear wheels are pushing the car, which will make the front wheels slide, causing under steer.
Ever see the ROH Snypers? They look like that have spacers built onto them.
Car: 86 Iroc-Z28
Engine: FB385
No i don't, sorry! Even if i did i wouldn't know how to post them. I do have the wheels mounted and balanced, ready to put on. It is just that i do not want to mess them up while i do my motor swap. I am selling my SS wheels that i had on the car though. Had to throw that in there! Well, ES87iroc saw them when he picked up his new gfx so i am not lying but i do not have any pictures, sorry. They are off of a 2002 too. later
Not going to argue but I thought I would let you know that I don't believe in having a rim that isn't designed to fit our vehicles. If you do get a FWD rim, you have to spend a lot more money to get them to fit properly is what I am saying, and I think it looks cheesy.
And if that isn't enough, think about that adapter moving the center point of the rim back... and you are saying it is as strong by moving the center backward? You are taking a stong point and turning it into two weaker points. You are physically changing the angle of steer!!! It's simple physics. The car has to work harder to turn them etc etc....
With the right spacers, the angle may be corrected, but how much money have you spent? If you want to have those kind of rims, it's your perogative, but like I said, it really does look cheesy.
That's my .02
That's my .02
Car: 86 Iroc-Z28
Engine: FB385
I know what you mean about it being weak! I wonder if it would be really safe to break loose with my new motor while using wheel adapters? Until i get some money for a set of Simmons or Fisk wheels i will be using the ZO6 wheels! Does anyone know what the wheel adapters are good for, rated at for safety? I got mine from Andris Skulte and so i should probally give him an e-mail to confirm! later
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I thought the point of the adapters was to correct the wheels to get the zero offset?
the adapters use a total of ten lugnuts. THe adapter bolts onto the axle just like the wheel, and then the wheel bolts onto the adapter. Its made out of billet aluminum, Its should be just as strong!
:sillylol )
Hehehe
